if food sticks to your cast iron pan?
Postby slowcowboy » Fri Jan 31, 2014 6:48 am
what happens after frying that moring egg when the food or the egg sticks to your pan. how do you clean cast iron that has food sticking to it?
slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
6000 Club
6000 Club
Images: 166
Re: if food sticks to your cast iron pan?
Postby kayakdlk » Fri Jan 31, 2014 7:13 am
Slow
I let it soak a little bit with water, sometime heat up the water a little bit and use plastic scraper or scrub brush, it should come right off. You can also use salt as an abrasive. Then re-coat with oil.
Dan.
kayakdlk
Images: 389
Postby Catherine+twins » Fri Jan 31, 2014 10:12 pm
slowcowboy wrote:what happens after frying that moring egg when the food or the egg sticks to your pan. how do you clean cast iron that has food sticking to it?
slow
ChoreBoy http://choreboyscrubbers.com/Products/U ... Steel.aspx
I have a spiky handle for mine, like this but without the soap dispenser
http://www.amazon.com/niceeshop-Stainle ... ber+holder
And then there is this one, which I got for a friend who cooks for guys in armor and chain mail
http://www.amazon.com/Chain-Mail-Cast-I ... m_sbs_k_14
Catherine
Catherine+twins
Images: 124
Postby wagondude » Sat Feb 01, 2014 5:22 pm
Our Scout troop uses a scrubber made from loosely crumpled aluminum foil. Another option is to stir some hot coals in it then oil it back up. But I have found that heating water in it and scraping with a bamboo spatula works quite well.
Bill
101137
wagondude
Images: 35
Postby doitright » Sun Feb 02, 2014 3:46 pm
Having something stick every now and then just happens. Hot water and a little scrubing is all it takes to fix it. Then go back to work and put a good season on it. It would have never have stuck if it had a good season on it. With all my pans and pots I like to deep fry in them a few times after seasoning. But my wife tells me all the time her egg pan is for eggs only same with her cornbread pan!
Kevin
doitright
REAR DOOR CAMPER
1959 REAR DOOR SCOTTY
doitright
Images: 38
Return to Cast Iron
