Found at thrift store, but what is it?
Postby the other side » Sat Mar 08, 2014 7:54 pm
I found a 1 qt cast iron pot (made in U.S.A. and 1 QT on the bottom, 1 on the inside of the lid) with a lid that has 4 holes in the top. The holes are big enough to fit my finger in it. It doesn't look old. It has 2 solid tabs for handles and a solid half circle tab on the lid (to lift the lid with). I paid $4.00 for it because it was cute, but what the heck is it? I am at the hospital and have no access to a camera, so no pics yet. I have tried searching the net, but can't find a pic of it anywhere. Thanks! :)
the other side
Images: 10
Re: Found at thrift store, but what is it?
Postby The Teardrop Nanny » Sun Mar 09, 2014 10:37 am
It may be for putting water in and setting on the stove to allow for humidity (wood stove topper) in a room. :R
There are many different designs, some are figures, but post a pic when you can. TDN
Life's uncertain...eat dessert first. Click on the icons below to see more of my neck of the woods.
ImageNanny's Niche' Image[img]
The Teardrop Nanny
Teardrop Muse
Postby the other side » Sun Mar 09, 2014 11:28 am
My husband and I were thinking potpourri (possibly), but what a heavy container for something as nothing as potpourri. It is so small that the water it could hold to humidify the air wouldn't be worth the effort of repeatedly filling the container. I'll try to borrow a camera. Thanks
the other side
Images: 10
Postby KCStudly » Sun Mar 09, 2014 9:36 pm
Garlic roaster?
Images: 8116
Postby the other side » Sun Mar 09, 2014 11:16 pm
117704
Ok here is the picture of the cast iron thrift store find! Anyone know what it is?
the other side
Images: 10
Postby the other side » Sun Mar 09, 2014 11:46 pm
117705
Here's another pic of the pot, but the soda can makes it look smaller than it really is in real time.
the other side
Images: 10
Postby the other side » Mon Mar 10, 2014 11:46 am
I did a search for cast iron garlic roaster (cuz I thought that was a possibility). The garlic roasters have a shallow bottom and a volcano looking top. This is going to drive me CRAZY!
the other side
Images: 10
Postby tac422 » Mon Mar 10, 2014 12:40 pm
Egg poacher missing the trays ?
for tiny eggs ?
or Egg steamer ?
tac422
Images: 220
Postby bobhenry » Mon Mar 10, 2014 1:11 pm
9000 Club
9000 Club
Images: 2318
Postby the other side » Mon Mar 10, 2014 1:22 pm
Sure does look like it would serve the same purpose, but why can't I find a picture of the one I have anywhere? If mine is so old they don't have a pic of it, then it is in MINT condition. But if mine is a newer piece, then why can't I find a pic of it anywhere?
the other side
Images: 10
Postby MtnDon » Mon Mar 10, 2014 8:26 pm
Incense burner
MtnDon
Images: 24
Postby the other side » Mon Mar 10, 2014 9:57 pm
We thought about that too but we kind of thought 1 quart of a heavy cast iron pot was over kill for a small cone of incense!? Mine can't be the only one out there can it? All ideas are very welcome and needed!
the other side
Images: 10
Postby KCStudly » Mon Mar 10, 2014 10:01 pm
Are the holes in the lid cast in place by the OEM, or were they drilled in after the fact? If drilled it could indicate that it was somebodies modification and could have been done for any number of reasons, such as the wood stove humidifier. They make some pretty small wood stoves.
Images: 8116
Postby the other side » Mon Mar 10, 2014 10:45 pm
It appears to be made that way because the holes inside the lid are slightly bigger on the inside of the lid, going to ever so slightly smaller on the outside of the lid (like tapered). And, you can see the bumpy cast iron imperfections. It looks too original to me. Plus there is a very slight ridge that appears to be from the casting and looks like it needed a little more sanding to make it smoother (but it is all consistent imperfections). But when I first saw it in the thrift store I thought someone had drilled the holes until I picked it up and looked closer.
We used to heat strictly by wood. We had different types and sizes of stoves. This thing is too small for that. You'd have to refill it every hour or two. Even with our smallest stove (the small potbelly size you saw in the old trains) we used the cast iron teapot and we STILL had to refill it way too much.
the other side
Images: 10
Postby Juneaudave » Mon Mar 10, 2014 11:10 pm
Maybe it is a smoker pot that you fill with wood chips and set in a gas grill :thinking:
Juneaudave
Images: 372
Return to Cast Iron
