My New (old) Teeny Tiny Hibachi
Postby deleted » Thu Jun 05, 2014 10:49 am
It's 5"x5" which = 25 square inches of grilling awesomeness in perfect proportion to The Glampette and dinner for one! My other vintage grill was too cute to dirty up with charcoal so I found a solution on Etsy. Even though the body is cast iron it's not very heavy at all. I used wood coals instead of briquets. They worked just fine. Really pleased that it's more functional than I thought it would be.
:lol:
More pictures and balsamic glazed veggie recipe in today's blog post:
http://theflirtyguide.blogspot.com/2014/06/eeeeeek-teeny-tiny-hibachi-for-glampette.html
deleted
Images: 85
Re: My New (old) Teeny Tiny Hibachi
Postby Woodbutcher » Thu Jun 05, 2014 7:39 pm
Staci, that is the perfect grill for you. As I was scrolling down the pictures I thought, I bet she has to cut a hot dog in half to cook it and then I saw a sausage cut in half. That is the most petite grill I have ever seen. Did it come with little grill tools. Since you have a theme going, it would be cool to have some micro tongs. :lol:
Woodbutcher
Postby working on it » Thu Jun 05, 2014 7:48 pm
Stacie- that may be the perfect grill...but, you need a matching oven, perfectly sized for your trailer, and colored to match your grill.
Susie Homemaker Oven.jpg (64.06 KiB) Viewed 1297 times
  • 2013 HHRv,"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • featuring:
    • 3500 lb Dexter axle,
    • 27x8.5-14LT tires,
    • LED lighting,
    • A/C & heat,Optima AGM battery,
    • extended-run 2500w generator,
    • Coleman dual-fuel stove & lantern
  • 147697148333125895
  • 148599148106
working on it
Images: 427
Postby deleted » Fri Jun 06, 2014 8:46 am
Great ideas! I need both :lol:
deleted
Images: 85
Postby PKCSPT » Fri Jun 06, 2014 11:10 pm
Now if I could find one of those I might do a little cooking when I camp
141240 145569147706
PKCSPT
Images: 60
Postby bobhenry » Mon Jun 09, 2014 6:17 am
There is one in here starting at $5.00
http://www.ebay.com/sch/i.html?_nkw=mini+hibachi+grill
9000 Club
9000 Club
Images: 2286
Return to Cast Iron
