Page 1 of 1
Causes of castbirin durch ovens to crack.
PostPosted: Sun Mar 26, 2017 1:05 pm
by slowcowboy
Lets duscuse when a castirin pot cravks what caouses it...my dad has a idea of the corn bread I cooked thecdoyfh was cold and my Dutch oven half full and it was a change in temputures? Any ideas on causes of cracked cast iron pots let's discuss it here..
Sent from my SAMSUNG-SM-J320A using Tapatalk
Re: Causes of castbirin durch ovens to crack.
PostPosted: Sun Mar 26, 2017 6:11 pm
by Woodbutcher
I cook my corn bread in a cast iron skillet in the house. Never tried it in a DO. But I always preheat my skillet before pouring in the batter. Never had a problem.
PostPosted: Sun Mar 26, 2017 7:51 pm
by S. Heisley
Drastic changes of temperatures can cause cast iron to crack; but, maybe there was a small, nearly invisible fissure or a weak spot already in the DO. You may never know the full answer.
PostPosted: Sat Apr 01, 2017 6:32 pm
by slowcowboy
I found my problem I pre heated the do on a coleman stove than say it in my do table while I heated my charcoal with cold batter inside yep drastic temp changes I should have had got coals under it before I poured the xirn bread batter into it while the coals heatedvit as I poured into the pan.
