Home shop built cooking tools.
Re: Home shop built cooking tools.
Postby Sparksalot » Sun Mar 01, 2020 10:09 pm
I haven't made any cooking tools. I like that license plate wind barrier you have.
I recently saw a cooking gizmo called a skottle. https://tembotusk.myshopify.com/product ... kottle-kit
With a burner this thing is over $300. I'm thinking no way. Recently a guy had one on a trip, it did a great job cooking, but it's really just a plow disk on legs.
I had a plow disk in the garage, so I've started down the path of making one. I broke out my grinder to trim a piece of steel to plug the axle hole, then started welding.
161235
161236
Sparksalot
Images: 682
Postby tomhawk » Mon Mar 02, 2020 1:16 pm
I posted about a trivet made from rebar two years ago Dutch oven trivet.
Since then I have made several more including one that fits an 8 inch DO. I am pleased with the way these work. They provide plenty of stability for the pot or lid. They are compact and store inside their intended pot. Depending on the bolts you use, they are adjustable in height.
The main problem I had was bending the rebar. I would blame that on my deficient metalworking knowledge.
Otherwise they are pretty easy to assemble. All you need are a few spot welds.
I have enjoyed having these around. I use them a lot.
Evolution is driven by mistakes, not plans.
My build: https://www.tnttt.com/viewtopic.php?f=55&t=75248
tomhawk
Images: 100
Postby bobhenry » Tue Mar 03, 2020 5:51 am
A FEW !
This one got me in trouble with the Mair folks for patent infringement !
Images: 2614
Postby dirtsailor2003 » Fri Aug 28, 2020 12:18 pm
I have all kinds of homemade cooking gadgets. My most used one though is my Rally rim burner that I made out of a 16" rally rim, three horse shoes, some black iron pipe, cooking grate and a bayou classic propane burner. Originally built it for my homemade discada. I also use it with my dutch ovens, wok, paella pan, etc.
[imghttps://live.staticflickr.com/65535/50275086192_d8ed6e0f7e_c.jpg[/img]
Cheesy tater tots
dirtsailor2003
Postby twisted lines » Fri Aug 28, 2020 12:39 pm
So nice :beer:
Racking up; And Rapin foam
twisted lines
Return to Cast Iron
