Question about a Coleman 242C lantern.
Postby Dean in Eureka, CA » Sun Jan 25, 2009 11:17 pm
Texas Teardrop,
The 200 and the 242 are both single mantle.
I'm curious to know if your burner frame has two legs, one on each side of the generator tube... Or if it only has one leg, off to the side of the generator tube.
My hunch is that somebody wanted to trick out a 200 and put the nickel fount on it and gave you the 242 with a 200 fount.
It doesn't make sense to me for your lantern to have a 242 colar and a 200 burner frame.
BTW- I'd take a 242 over a 200 anyday and you can on occasion find just the nickel fount for a 242 on Ebay... If that is the case. (You have a 242 with a 200 fount)
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Texas teardrop » Sun Jan 25, 2009 11:33 pm
Thanks for all the help, guys!
I'm not a purist on this one.. Guess I'll use Doug's suggetion and go with the hunter green or paint the bottom with a Texas flag to match the outside of my Teardrop.. gotta do a little thinking on this one :thinking:
Texas teardrop
Images: 5
Postby Texas teardrop » Sun Jan 25, 2009 11:39 pm
Dean, it has the 2 legs..
It's just going to be a lot of fun deciding what to do with it... It's certainly not going to be original... Just a good user.
I'll just keep looking around for an original one that's in really good shape.
Texas teardrop
Images: 5
Postby doug hodder » Sun Jan 25, 2009 11:43 pm
Since it is a morphed lantern and someone has taken it apart....pressure it up, see if it holds overnight...if it doesn't, check all fittings. Just an idea. Have fun with it and enjoy! Doug
Postby Texas teardrop » Mon Jan 26, 2009 11:21 am
Rainjer, you sure have that right.... I just took it all apart.. doesn't look too bad. Now to do some sanding, primering and painting.. My wife doesn't thing I got one of my "better deals" but that's just fine... Ya can't win all the time.
Texas teardrop
Images: 5
Postby rainjer » Mon Jan 26, 2009 11:46 am
I like how the 242 burns better than the 200A. The 242 is also a little brighter.
Jeremy
rainjer
King Koleman
Images: 11
Postby Texas teardrop » Mon Jan 26, 2009 12:15 pm
When I get it all cleaned up and painted I'll see how it work..
I see you're from Everett... My son, daughter-in-law and grandson live in Granite Falls.. I lived all my life in Olympia and moved to Texas nearly 4 years ago... I sure don't miss all your rain... :)
Texas teardrop
Images: 5
Postby rainjer » Mon Jan 26, 2009 12:51 pm
Born & raised here so rain does not bother me. As they say, Washingtonian's don't tan, they rust...
Jeremy
rainjer
King Koleman
Images: 11
