Vintage Coleman and other stuff....
Postby PresTx82 » Sat Nov 15, 2008 3:52 pm
I picked this up on Ebay awhile back:
Looks good brewing a pot of coffee. It's the "work horse" of the Coleman line.
Mark
El Paso, Texas
PresTx82
Postby WarPony » Sat Nov 15, 2008 3:55 pm
Micro469 wrote:Just picked these up this morning on Craigslist...
Man, this is bull$hine!!! We don't have any cool stuff here it T-town like you've come across this past week!!!
:cry: Jeff
WarPony
Images: 289
Postby rainjer » Sat Nov 15, 2008 5:22 pm
Is this stove ID'ed. It almost looks like it could be a 500B.
Jeremy
rainjer
King Koleman
Images: 11
Postby rainjer » Sat Nov 15, 2008 5:30 pm
:cry: Jeff
Are you willing to go to Kansas City? Here area couple great deals.
http://kansascity.craigslist.org/clt/918907538.html
http://kansascity.craigslist.org/spo/890102585.html
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Sat Nov 15, 2008 6:45 pm
Jeremy
No ID. Stamped on the side it says COLEMAN, THE SUNSHINE of THE NIGHT, Made in Canada
John
Micro469
Images: 382
Postby rainjer » Sat Nov 15, 2008 7:26 pm
Is there anything stamped on the bottom of the tank?
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Sat Nov 15, 2008 7:31 pm
rainjer wrote:Is there anything stamped on the bottom of the tank?
Jeremy
Nope
John
Micro469
Images: 382
Postby doug hodder » Sat Nov 15, 2008 9:10 pm
PresTx82 wrote:I picked this up on Ebay awhile back:
I'm thinking about a stove like that Mark for waffles only! Make up a frame to support the waffle iron, and not have to worry about throwing heat out into the body of the stove like on a 2 burner. A ring of aluminum would work well, do you know how long you can run that stove full tilt? Fuel supply and pressure is necessary when cooking waffles for a number of people. Doug
Postby doug hodder » Sat Nov 15, 2008 9:33 pm
Here's where I am with the restoration of the mid 20's Handy Chef. It needs a new generator, but I got it bead blasted thanks to Mike A for the use of his cabinet, polished the tank and other parts, and got it in primer. Haven't worked out the paint job on it, but I'm sure I'll use some mint green just to bug Rich! Doug
Postby satch » Sat Nov 15, 2008 9:41 pm
doug hodder wrote:Here's where I am with the restoration of the mid 20's Handy Chef. It needs a new generator, but I got it bead blasted thanks to Mike A for the use of his cabinet, polished the tank and other parts, and got it in primer. Haven't worked out the paint job on it, but I'm sure I'll use some mint green just to bug Rich! Doug
Lookin' good Bro! :thumbsup:
If it itches. scratch it
Rick
satch
Images: 63
Postby rainjer » Sat Nov 15, 2008 9:55 pm
They are about 10,500 BTU.
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Sat Nov 15, 2008 10:39 pm
Mark, mine looks a little older than yours, my gas tube is cast not pressed like yours. Underneath I seem to have a bent wire, it doesn't move.... supposed to be some sort of valve??????
John
Micro469
Images: 382
Postby Micro469 » Sat Nov 15, 2008 10:41 pm
Doug... How did you clean up the burners and the pipes? They allways seem to look the worst after you use it, but yours look brand new.....
John
Micro469
Images: 382
Postby halfdome, Danny » Sat Nov 15, 2008 10:49 pm
They use to sell a metal covering for that one for a heater. It would clamp on and I think it had a bail handle too. We use to use mine in my brothers very drafty 56 Chevy pick up. It would get real hot at times. The things we did when we were younger :roll: . Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby doug hodder » Sat Nov 15, 2008 10:51 pm
John...typically on a stove, you turn that valve up to light it and crack the fuel knob about 1/4 turn and light it, listen and you can hear when the fuel hits the burner....after a while, then move it into the down position. The generator or tube that it fits into, needs to heat up to help atomize the fuel for the burner. If it flares up with a bright yellow flame, it's flooded and not atomizing the fuel well enough....at least that's what I had always heard, but that's for the larger 2 burners. I'd imagine it's the same thing for the single burner. But then I haven't owned one of those and I'm still learning all of this stuff between the different models and lanterns.
Check the instructions that appear to be stamped in the flame base. As for the appearance of the tubing etc.....I've taken them apart and cleaned/polished up the parts. They won't look that good after they have been burned for any time. Some of my stuff doesn't work when I get it, so take it all apart and pretty it up and repair it. Doug
