doug hodder wrote:I'd pressure up the fount...shut the valve completely down and see if you get any fuel leaking off into the generator as a starting point. Doug
I've done that. Can't see any fuel or hear any hissing.
Micro469 wrote:rainjer wrote:Did you verify the tip is on there now?
I would pull the generator off an check out. The easiest way is to take the frame nut off an just lift the entire frame off. Make sure the tip is on the generator. If so take the generator off an make sure the wire is still there. Also make sure the generator is hooked in the eccentric block. The other thing you may check to see if the screen is still in the burner.
Jeremy
Brand new generator. Yes it's installed correctly. And the screen is still in the burner and clean....
rainjer wrote:Micro469 wrote:rainjer wrote:Did you verify the tip is on there now?
Jeremy
I am not try to say you don't know what you are doing. I had a similar problem on another lantern. I did what I said above & double checked everything, put it back together and it worked fine. I don't know what I did to fix it but whatever it was it worked.
The gurgle is normal, that means you are getting gas thru the generator. It will quite out once it star running. You should hear air & the the gurgle.
Try de-pressurizing the tank, then open the valve all the way up with the gas cap off, close the valve, put the cap back on and then re-pressurize it.
Jeremy
rainjer wrote:A friend of mine on the Coleman forum is saying you have a plugged air tube. The tube the generator goes into. Take a piece if wire the attach a piece of steel wool to it & run it thru it from the top all the way to the bottom.
Also, what kind of fuel are you using?
Jeremy
rainjer wrote:The air tube is the tube the tip of the generator goes into. It is attach to the frame. It goes from the top if the frame to the bottom of the frame.
Jeremy
Micro469 wrote:rainjer wrote:The air tube is the tube the tip of the generator goes into. It is attach to the frame. It goes from the top if the frame to the bottom of the frame.
Jeremy
Just checked it out. Destroyed my mantle, but what the heck. Dissasembled the air tube...clean as a whistle.....
rainjer wrote:Micro469 wrote:rainjer wrote:The air tube is the tube the tip of the generator goes into. It is attach to the frame. It goes from the top if the frame to the bottom of the frame.
Jeremy
Did you run some steel wool thru it? You can not see all the way thru the bend. Also check the u tube really well.
Jeremy
rainjer wrote:And you ran the pipe cleaner thru the rest of the air tube in the frame?
Jeremy
