Generator Spring Stuck in Generator Tube
Postby PresTx82 » Sat Apr 18, 2009 8:44 pm
I'm doing a break down and rebuild on my 99 cent 425 stove, and I'm having a little problem with the generator spring.
Has anyone had a problem getting the spring out of the generator? The spring is stuck in the generator tube. I got it soaking in liquid wrench right now, but its wedged in there real good. A lot of carbon build up.
I'm sure I just have to be patient.
Mark
El Paso, Texas
PresTx82
Postby rainjer » Sat Apr 18, 2009 8:48 pm
I have read heat it up with a torch. I have not tried it but some say it will work.
Jeremy
rainjer
King Koleman
Images: 11
Postby PresTx82 » Sat Apr 18, 2009 8:54 pm
FIRE!
Yes, fire.
FIRE GOOD!
Mark
El Paso, Texas
PresTx82
Postby doug hodder » Sat Apr 18, 2009 8:59 pm
Carburetor cleaner works well on the carbon. I've got a couple of stoves that I couldn't get the spring out of. Did what I could to clean them up, carb cleaner, air blasts...stuck them back together and they worked. Neat little tray for soaking them in... :thumbsup: Doug
Postby PresTx82 » Sat Apr 18, 2009 9:40 pm
I'll let it soak overnight then get the blow torch out tommorrow. :twisted:
I "torched" the ends of a piece of PVC and sealed the ends in my vise, then cut the top off and laid my generator in there. Its a nice little soaking tray. :thumbsup:
My stove is almost done. Looks good. I took some pictures during the process. I'll post when completed.
I will need to order me a decal from the decal guy to complete the project. 8)
Mark
El Paso, Texas
PresTx82
Postby PresTx82 » Tue Apr 21, 2009 5:18 pm
As a last resort I tried electrolysis last night. I loosened it up pretty good, but not good enough. I ended up pulling the spring out, but stretched it so bad it'll never fit back in the tube. :cry: Hey, at least I tried!
I'll be ordering one from Robert Hitchcock, the parts guy.
Mark
El Paso, Texas
PresTx82
