Gas pressure appliance question(s)
Postby tinksdad » Sat May 09, 2009 12:39 pm
What do you guys (and gals) use to polish your brass parts?? Being basically cheap, I've been using something readily available in my house.... ketchup thinned down with a little water and a tooth brush. I don't know if it's detrimental to the brass or not, but they sure do shine when I'm done.
Also, would a thin coat of clear coat after they are cleaned and polished help them stay that way, or am I spinning my wheels on that??
If it stops raining long enough to get to the work shed to do some painting (power has gone out twice so far this morning), I might be able to post pics of my first two re-builds later this evening.
tinksdad
Images: 155
Postby Kevin A » Sat May 09, 2009 1:01 pm
Here's what I've used in the past for polishing brass. In combination the two products work really well.
Kevin A
The other guy
Images: 289
Postby rainjer » Sat May 09, 2009 1:16 pm
I use vinegar and soak them. Then hit them with a little 0000 steel wool. Make sure you do not put any steel in with the brass or the brass will turn pink.
Jeremy
rainjer
King Koleman
Images: 11
