Can you spot the modification?
Postby TLC » Tue May 26, 2009 6:12 pm
OK, Coleman experts, how sharp are your eyes? I made a $2.00 modification to this 200A to help protect the paint and vent. Can you spot it?
Hard to see isn't it? Well I covered the bale handle with clear heat shrink tubing right down to the 90 degree bend. I think it will protect both the paint on the fount and the vent from metal to metal contact. Cost was 2 dollars and some change for a 4' length of the tubing.
What do you think? Worth it?
I can drink all day.....provided I don't start till 11PM
TLC
Images: 100
Postby dobyman » Tue May 26, 2009 7:00 pm
You were telling me you were going to do it. I LIKE IT! cant even tell its there and will save a lot of chipping in the fount! Now I have to do mine! :thumbsup:
Dobyman!
If you can't find it at a rummage sale..... you dont need it!
dobyman
Images: 67
Postby Alan Wood » Tue May 26, 2009 9:38 pm
Great idea there :thumbsup: And if you ever do go to sell the lantern it can be removed with a bit of effort I think.
Alan Wood
Alan Wood
5000 Club
5000 Club
Postby TLC » Tue May 26, 2009 11:34 pm
Alan Wood wrote:Great idea there :thumbsup: And if you ever do go to sell the lantern it can be removed with a bit of effort I think.
It can be removed by just slitting it with a razor blade. It's not bonded to the bale.
TLC
Images: 100
Postby doug hodder » Wed May 27, 2009 8:52 am
If it's not bonded to the bale, can water get in and cause the bale to rust do you think? I've got some really rusty ones. I've been wrapping the peak on the bale with a piece of narrowed up electrical tape. It only hits at the 1 spot. It's a slick idea however. :thumbsup: Doug
Postby TLC » Wed May 27, 2009 9:51 am
doug hodder wrote:If it's not bonded to the bale, can water get in and cause the bale to rust do you think? I've got some really rusty ones. I've been wrapping the peak on the bale with a piece of narrowed up electrical tape. It only hits at the 1 spot. It's a slick idea however. :thumbsup: Doug
Doug:
Although it's not bonded to the bale, you can make it as tight as you want it by applying more heat. I did this one tight enough to keep it from twisting. I don't think water will be an issue, but time will tell. Being clear, I can keep tabs on it.
TLC
Images: 100
Postby xrover » Wed May 27, 2009 9:21 pm
Will it melt?
1988 Cadet
2006 Argo Avenger
xrover
Images: 22
Postby TLC » Thu May 28, 2009 7:21 am
xrover wrote:Will it melt?
It hasn't so far! Stays cool to the touch.
TLC
Images: 100
