Military 252
Re: Military 252
Postby campmaster-k » Thu Apr 11, 2013 10:45 pm
alex k wrote:are the 252's affected by the wind ?
mine is fine on the table , but when i hang it on the deck and there is wind gusts over 15mph it flickers and dims . :cry:
move it out of the wind and it brightens up .
anyone else have the same occur ?
Alex. These lanterns are vety effected by temp. Mine is a monster without glass.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: Military 252
Postby Wolffarmer » Fri Apr 12, 2013 12:36 am
Yes, without the glass, or even one panel out they are hopeless.
Randy
Wolffarmer
Images: 305
Re: Military 252
Postby Wolffarmer » Fri Apr 12, 2013 12:41 am
campmaster-k wrote:Mine is a 1952 Coleman. Which lanterns had the quadrant glass?
I do not know. My 58 Coleman 252 has a globe marked US. No sign there was ever guides for the planes on the frame and it was in mighty fine condition when I got it. Probably only burned a few times. That has been corrected. My later 252s all have the quads in them. On one I replaced 2 of them with aluminum for a poor mans reflector. Does work to good at reflecting light as they are not polished but the lantern burns with no problem.
Randy
Wolffarmer
Images: 305
Help Me??!! Re: Military 252
Postby SuperShady1 » Tue May 28, 2013 11:43 am
Hi can anyone tell me what the tools are used for on the 252? One is to remove the generator nut...
I have a really sweet one that has very low miles on her...but a dickens to fire up. :?
The inside of the genrerator has a wick in it? Do I need a new generator?
The fount is is holding pressure, gasket is good, leather is oiled and pump is smooth. :thinking:
Take generator off and it is gettin fuel into the cage. :thumbsup:
Do I need a new Generator or is there something else I am missing or need to look at? :thinking:
Thanks again.
Shady
Its a beautiful world we live in
A sweet romantic place
Beautiful people everywhere
The way they show they care
Makes me want to say
For you, for you, for you
Coleman Keepers 200A Gang
SuperShady1
Images: 318
Re: Military 252
Postby Zollinger » Tue May 28, 2013 11:51 am
Shady, Your right it sounds like the generator could be bad. Although military lanterns do have a reputation of being hard to light and run loud. Is it a straight gererator or the one with the circle in the middle? I think (BUT I could be wrong) that the wick might be stock.
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Re: Military 252
Postby SuperShady1 » Tue May 28, 2013 11:55 am
Zollinger wrote:Shady, Your right it sounds like the generator could be bad. Although military lanterns do have a reputation of being hard to light and run loud. Is it a straight gererator or the one with the circle in the middle? I think (BUT I could be wrong) that the wick might be stock.
it is the question mark generator. 1952. the inside of the generator has a wick inside it?? Does that need to be primed?
Do you know what the tip cleaner is used for??
Thanks again,
Shady
SuperShady1
Images: 318
Re: Military 252
Postby Zollinger » Tue May 28, 2013 12:01 pm
Thanks again,
Shady
I do know that once the wick is out it is nearly impossible to replace. I haven't been lucky enought to find a military lantern at a price that I can afford. I would try to heat up the generator with a torch or lighter to get the fuel vaporized so it will not flood and turn into a fireball. Don't have a clue what the tip cleaner or other tools are for. Hopefully someone else will come along that knows more about your lantern.
Dawn
Zollinger
Images: 64
Re: Military 252
Postby Wolffarmer » Tue May 28, 2013 8:37 pm
If you have the tools that was sent with the 252s there is a little tip cleaner in there. I unscrew the jet off the generator and clean from the inside out. Try that and see.
Randy
Wolffarmer
Images: 305
Re: Military 252
Postby doug hodder » Wed May 29, 2013 7:46 am
Another thing about the 252 that people forget....it's a low pressure lantern...don't put a whole ton of pumps into it before you fire it up...Doug
Re: Military 252
Postby SuperShady1 » Fri May 31, 2013 10:16 am
doug hodder wrote:Another thing about the 252 that people forget....it's a low pressure lantern...don't put a whole ton of pumps into it before you fire it up...Doug
Gotcha...how many pumps would be the norm ...10? 15? Going to clean the nozzle and prime the generator and give it a go.
Shady
SuperShady1
Images: 318
Re: Military 252
Postby alex k » Fri May 31, 2013 11:21 am
i do 10 pumps . open the valve till fuel sputters our , then close valve . then light match and open valve 1/2 turn .
watch out for big flame :shock: . then close valve again .
when mantle is burning good , about 30 sec , i open valve again
later add 10-15 pumps , but watch for flareups
i do light it by removing one side of glass .
this seems to be how my smp is best started :applause:
not to be confused with alexk from california
Green Lantern Corpsman
alex k
Images: 34
Re: Military 252
Postby SuperShady1 » Fri May 31, 2013 11:35 am
alex k wrote:i do 10 pumps . open the valve till fuel sputters our , then close valve . then light match and open valve 1/2 turn .
Thanks for the tips!"
SuperShady1
Images: 318
Re: Military 252
Postby SuperShady1 » Tue Jun 11, 2013 2:40 pm
I got a wrench and the tip cleaner and went to town on the 252. Put in a new mantle!! :D
Now she roars and put of a nice lite!! :twisted:
Here are a couple of :pictures: :pictures: :pictures: :pictures: :pictures:
108053
108054
108055
108056
Thanks for all the help....
Oh I also sanded and painted the funnel in an automotive silver high temp paint. :thumbsup:
Looks nice!!
Shady
SuperShady1
Images: 318
