Bride of Frankenstein - Pic heavy.
Postby campmaster-k » Sun Sep 29, 2013 2:25 pm
Here is my frankie. I think I will call her Francis.
The Turd had broken glass. :x
You have heard of polishing a Turd!
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: Bride of Frankenstein
Postby campmaster-k » Sun Sep 29, 2013 2:29 pm
I had never really seen the guts of a 275 before.
Cut off brass, installed bushing with form a gasket and test fit 200 guts.
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Sun Sep 29, 2013 2:34 pm
Painting had challenges. Weather, hi tech sprayer malfunction. Still it came out pretty good.
The paint is single stage auto paint I had made to match Coleman Red. I have a machine that will put it in spray cans.
-Kirk
Build thread -
campmaster-k
Postby Mukilteo » Sun Sep 29, 2013 2:40 pm
good start. :D
I use a roll of tape for a platform when painting.
Eric
Mukilteo
Images: 14
Postby campmaster-k » Sun Sep 29, 2013 2:50 pm
What I did on the bushing is I cleaned everything then I just screwed in the 275 guts minus the pickup tube. Then I hacksawed it off at the base. That way I did not have to do two cuts. I worked great. Then I filed it smooth, tapped it, then paint. 8)
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Sun Sep 29, 2013 2:51 pm
Mukilteo wrote:good start. :D
I am not patient so a roll of tape would have stuck in my wet paint but that is a good idea. :lol:
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Sun Sep 29, 2013 2:53 pm
I dont get to play Coleman as often as I would like. Pretty fun!
-Kirk
Build thread -
campmaster-k
Postby Mukilteo » Sun Sep 29, 2013 6:37 pm
Day 1- I paint the bottom and let it dry.
Day 2- I paint the top.
Day 3- I cure it in the oven.
While waiting for all this to happen I have other projects I'm working on.
Don't get the paint too thick around the pump tube. You'll chip the paint putting on the metal cap.
I primer it once than mask off just enough for the cap.
Eric
Mukilteo
Images: 14
Postby campmaster-k » Sun Sep 29, 2013 7:17 pm
Well here she is. Day one paint, put on sticker, finish.
Thank you Eric for the inspiration and help on this project. I could not and probably would not have done this if you had not done it and taken the time to post it for us all to learn. :thumbsup:
-Kirk
Build thread -
campmaster-k
Postby doug hodder » Sun Sep 29, 2013 7:23 pm
Kirk...take a dowel and taper an end down. Thread it in on the tank bung, it acts like a handle, you can spray the entire tank in one shot, top, bottom, sides and get the entire thing done easily. Then just clamp it in a vice or somewhere to let it cure. Doug
Postby campmaster-k » Sun Sep 29, 2013 7:37 pm
doug hodder wrote:Kirk...take a dowel and taper an end down. Thread it in on the tank bung, it acts like a handle, you can spray the entire tank in one shot, top, bottom, sides and get the entire thing done easily. Then just clamp it in a vice or somewhere to let it cure. Doug
Great idea Doug.
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Sun Sep 29, 2013 8:13 pm
And the money shot.
I treated myself to a spanking new generator and this lantern may just be the best lantern I have.
-Kirk
Build thread -
campmaster-k
Postby Mukilteo » Sun Sep 29, 2013 8:20 pm
Awesome.
Eric
Mukilteo
Images: 14
Postby Zollinger » Sun Sep 29, 2013 8:25 pm
OOOO Shiny! You guys just keep raising the bar. Also Doug's idea with the dowl is one that I am going to have to borrow. :thumbsup:
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby campmaster-k » Sun Sep 29, 2013 9:06 pm
Ima do another one soon. What a great lantern with a huge tank. 8) :thumbsup:
-Kirk
Build thread -
campmaster-k
