Teardrops & Tiny Travel Trailers with Lifting Roofs
Re: Teardrops & Tiny Travel Trailers with Lifting Roofs
Postby proarch » Fri Nov 03, 2017 11:38 am
Here is the Purpledog. I am almost done with the build, but would like to share more about the design process sometime.
Paul R. Olson
Paul R. Olson Architects
Tucson, Arizona
proarch
Postby S. Heisley » Fri Nov 03, 2017 7:43 pm
proarch wrote:Here is the Purpledog. I am almost done with the build, but would like to share more about the design process sometime.
That looks like a nice drawing/painted picture. I look forward to seeing your build thread! :D
Images: 490
Postby Cathy P. » Tue Jan 02, 2018 11:46 am
Someone linked this into another website I belong to, and it is just interesting, kind of like a Hi-Lo without all the "bling": http://www.duckworksbbs.com/product-p/ww-slidavan.htm Hopefully this hasn't already been mentioned, as I didn't have time to read through all the other posts.
I wonder if one wanted one but didn't have the skills, if a local, more or less, person that worked in building cabinets would be able to do something like that.
Cathy P.
Postby John61CT » Tue Jan 02, 2018 12:24 pm
Yes I've been posting that everywhere, I think if you didn't need fine-art finishing, the functionality could be done by even handyman level carpentry skills, cabinetry not required.
I would want a flat(ter) roof for solar, and a bigger footprint, but def want to use that super simple lifting mechanism and fully insulated walls, just need a foam strip for sealing between the walls.
My idea is make it usable like a teardrop while lowered, say rest area sleeping while in transit.
Raising for longer stays just gives greater comfort and convenience.
John61CT
Postby Cathy P. » Tue Jan 02, 2018 2:40 pm
John61CT wrote:Yes I've been posting that everywhere, I think if you didn't need fine-art finishing, the functionality could be done by even handyman level carpentry skills, cabinetry not required.
I, too, would like to have the trailer to be usable for sleeping in the down mode, that would be a real plus, even if it was just crawling in.
This is a way to get more of the European style, light and simple, which manufacturers here just avoid.
Cathy P.
Postby S. Heisley » Tue Jan 02, 2018 10:04 pm
A lot of these designs here (but not all) are ones that a person can crawl into, to sleep in transit without putting the top up. I have done that with mine many a sleepy night. (However, since I'm fairly short, mine becomes a "slouchy" when the roof is down. HaHa!)
Some of these trailers even have a separate, short door (teardrop size) next to the bed just for the purpose of crawling into bed without needing to extend the roof.
Yes,the Duckworks' plans were mentioned in another thread but it is worth repeating here; so, thanks! :thumbsup:
Images: 490
Postby jschrotenboer » Mon Feb 12, 2018 10:06 pm
baughb wrote:Ok, Looong time lurker, possibly my first post.
Permission from my wife to spend the money to build (with very clever friends).
Came across Mr. "ez-toad" and his trailer 19 (for reference https://www.flickr.com/photos/51728468@ ... 661186740/). I hope to make this 14' long (if needed) and 6'6" wide (short Queen in back, central Cooking area with Dinette to the front) and keep the interior height to 5' with a "Hunter Compact" type roof that lifts up adding 18" or so of height. Not the whole length of the trailer but, more than half. also considering a 6" floor drop in the cooking area as well.
Totally stoked to find this thread because of the encouraging, simple ideas. My hope is that I don't have to scalp an existing Compact to get the roof I hope to have but, maybe someone on here may have some ideas for me or point me towards a source of info. I even looked into the uber-expensive van top conversions but alas, the 2 I contacted will only do motor vehicles.
So, that said, My name is Bob, I live in Burbank, CA. Try to get out at least monthly to the Eastern Sierra due to a fly fishing addiction.
Thanks for your time.
Have you ever checked out Home Grown Trailers' Woodland? I totally want to build something close to that but figured it'd be good to learn on a smaller teardrop first ;)
http://www.homegrowntrailers.com/woodlandImage
Sent from my SM-N950U using Tapatalk
jschrotenboer
Postby S. Heisley » Tue Feb 13, 2018 10:07 pm
Thanks! :thumbsup:
Images: 490
Users browsing this forum: Majestic-12 [Bot] and 2 guests
