![Image](http://img11.imagehosting.gr/out.php/i1410949_nose-2.jpg)
Bathroom will have a pump/tank, incinerator toilet. Using sheet metal siding. Not sure how to insulate, maybe squirted foam, maybe board, probably a mix. Want it to look Pro, don't want to bold a refrigerator to the nose!
Looking for ideas on how to get started. Thought about using toilet-seat covers for the jugs to nest in. Will have to use a ladder to get jugs in and out. Unless we do interior access through the kitchen but that seems like a lot of dirty work eventually best done on the outside, to my mind, please share any thoughts! I have measurements, like the jugs are 10" diameter, 19" high. Width of nose is 40", so I could stagger them and build a 1-tier shelf. The arms of the shelf will be supported by buttressed. Steel framing not to interfere with the prop-tank below. Total height from bottom of floor joist to top of wall is 92" (pre-peaked-style clerestory roof with scissor trusses). Fore to Aft measurement from nose-wall to top of the pipe-jack is 18".
Is there an appropriate sub-forum here? Perhaps someone can help by pointing me to a forum more interested in projects with these larger dimensions. I humbly submit that this looks like a fascinating community, just looking for any brainstorming to get done so I can do the work I need to do! Thanks
![Smile :)](./images/smilies/econ_smile.gif)
