dandan wrote:Hi Del,
good to see you back on it !
the 3.5" shown in the photo,
is that decreased when a load is placed on board ? Yes, how far is the question?
this may cause problems if anything is placed between the axle & floorpan. (if the tank can be reduced in size.) Plastic tank, pics later
perhaps mount it to the rear of the axle so its protected by it &
place a stone gaurd beneath too ??? The black tank is already there.
best rgds dan.
del wrote:Does anyone know what the lug bolts should be torqued at?
del
Do not care my torque wrench does both, just turn over.caseydog wrote:del wrote:Does anyone know what the lug bolts should be torqued at?
del
Do you want that in SAE or metric?
CD
del wrote:It escapes me why part is yellow. Now to do the same with the other side.
del
Hey I like that, now if I could only convince anybody that is why I did it?starleen2 wrote:del wrote:It escapes me why part is yellow. Now to do the same with the other side.
del
So you can see it under a dimmly lit trailer -Imagine pulling in about twilight and looking under a trailer in which everything is Black - the yellow kinda sticks out and is easy to find
