Hey all. im planning a design based on the lines of a
www.thesquidget.com
but instead of framing it out and stuffing foamboard inbetween the studs. im going to epoxy frp to foamboard then route out channels in the foamboard and epoxy in wood strips for my anchor points where cabinets and bedrails and such will tie into and then epoxy on a skin of luan.
also i will have a wood frame around the perimeter of the panels for something to screw into.
the roof will be built with the panes as well. the way i will do the roof is setup a scaffold on my shop floor and lay the luan over it clamp it down. then score and lay the foamboard over it to match the curves epoxy it down.
fill in the voids the scoring left and then epoxy the frp onto the foamboard and let that cure.
this should make a very strong laminate that wont flex once they are fastened together into the final shape.
i cannot wait to see the final weight vs what thesquidget.com''s ended up being.
im building this on a 4x8 harborfreight trailer. i have the folding style.
the camper will be a complete unit and able to slide off the trailer so i dont loose function of my trailer when im not out camping.
the floor will be framed with 2x2 to allow for 2in foamboard insulation on the floor.
with any luck this should be a super insulated little camper that can be taken on and off the trailer.
what i havnt decided yet though is thickness of foamboard to use.
and a method to fasten the panels together ie roof to walls and walls to floor.
