Bowtop Vard0 Questions
Postby amvet1944 » Mon Jul 04, 2011 9:57 am
I want to lightly paint the canvas of our 2008 built Bowtop. Any suggestions? Is this a good idea? Also I want to build the scrolled horseshoe end caps for our Vardo. Do you use 1x8's and cut several peices to make the horseshoe?
Gary & Linda Thorne :thinking:
amvet1944
43 veiws, and nobody has a clue
Postby amvet1944 » Tue Jul 05, 2011 12:09 pm
:cry:
amvet1944
Postby rbeemer » Tue Jul 05, 2011 2:57 pm
Gary,
On the painting of your roof I would say it depends on what is under neath it. If you are stretched between spars then the canvas becomes wet and may sag and dry. Paint may not be that flexible and when it dries you may have cracks every where.
Why are you painting it? If want to waterproof it they make stuff that waterproofs but maintains flexibility. Think scotchgard.
As far as the horseshoes you can try 1"x12"'s or do glue up. If you are painting it you might use mdf instead.
Rick
If ducks had scales, would fish quack?
rbeemer
Vardo painting
Postby amvet1944 » Tue Jul 05, 2011 7:09 pm
Thanks Rick. I never thought about it cracking, good point. I think I will try 1x12s. Thanks Gary
amvet1944
Postby sdakotadoug » Sun Jul 10, 2011 7:35 am
I agree on the flexable covering, I do however disagree on the MDF. That stuff is a water magnet and delaminating sawdust isn't a pretty sight. Doug
sdakotadoug
