The Geek's Lair
Re: The Geek's Lair
Postby GeekFisher » Tue Jan 01, 2019 10:51 am
Andrew Herrick wrote:Looks great! Be sure to leave minimum three inches of space between the tire and the fender. More (up to six inches) is better.
I should have around 5in of clearance. I staged everything Sunday and realized I'd have to go larger than expected for the fenders.
I'm stuck till Jan 14th for the metal stuff so I'll try to progress on everything else I can. I do have a challenge with doors actually. I can't seem to source hinges here in Canada :(
GeekFisher
Images: 61
Re: The Geek's Lair
Postby tony.latham » Tue Jan 01, 2019 11:07 am
How about piano hinges?
:thinking:
Re: The Geek's Lair
Postby GeekFisher » Tue Jan 01, 2019 11:41 am
:thinking:
I'm affraid these might leak (on the Hatch Galley door)
GeekFisher
Images: 61
Re: The Geek's Lair
Postby tony.latham » Tue Jan 01, 2019 2:34 pm
:thinking:
I was just suggesting for the doors (without any experience). Take a peek at Kayakdlk's build:
http://www.tnttt.com/viewtopic.php?f=50&t=57065
I'm leaning that way for my next build.
Re: The Geek's Lair
Postby GeekFisher » Tue Jan 01, 2019 6:52 pm
tony.latham wrote:I was just suggesting for the doors (without any experience). Take a peek at Kayakdlk's build:
I'll look at that. Side doors should be easier than the galley Hatch. I first thought on recessing it by lengthening the roof 1.5" (one 2x2 stud) so the hinge is not directly exposed to the elements.
GeekFisher
Images: 61
Re: The Geek's Lair
Postby GeekFisher » Sun Feb 10, 2019 10:46 am
Hey guys and gals,
Just a Quick message to let you know the project is not dead and I made some progress:
157259
I'm giving second epoxy coat this afternoon and should attach walls next week-end :)
GeekFisher
Images: 61
Re: The Geek's Lair
Postby lfhoward » Sun Feb 10, 2019 2:17 pm
Yay progress!! :applause:
Sometimes baby steps are all you can do, but you still move forward. The floor looks good.
lfhoward
Re: The Geek's Lair
Postby GeekFisher » Sun Feb 10, 2019 3:51 pm
lfhoward wrote:Yay progress!! :applause:
Doors is what makes me nervous actually.
GeekFisher
Images: 61
Re: The Geek's Lair
Postby GeekFisher » Fri Feb 15, 2019 7:05 pm
Some progress yesterday night:
157324157325
Starts to look like a camper !
GeekFisher
Images: 61
Re: The Geek's Lair
Postby twisted lines » Fri Feb 15, 2019 8:00 pm
I know where your coming from :NC but the walls are looking good.
Racking up; And Rapin foam
twisted lines
Re: The Geek's Lair
Postby GeekFisher » Sun Feb 17, 2019 11:12 am
Thanks !
Added some yesterday !
157327157326
Might add some on the angled nose. Rear is stiff but front still wobble and the angled ply might lack support as well.
What you guys think ?
GeekFisher
Images: 61
Re: The Geek's Lair
Postby GeekFisher » Sun Feb 17, 2019 4:44 pm
157333157332157331
Here's what I finally did
GeekFisher
Images: 61
Re: The Geek's Lair
Postby twisted lines » Mon Feb 18, 2019 12:46 pm
I think when you put your foam board in the front and 4 screws in the sheeting you will keep on going and not look back :thumbsup:
twisted lines
Re: The Geek's Lair
Postby GeekFisher » Wed Feb 20, 2019 2:25 pm
twisted lines wrote:I think when you put your foam board in the front and 4 screws in the sheeting you will keep on going and not look back :thumbsup:
I reinnforced a bit since theres not much structure up front but should be good to go now. Im reading stuff about building cabinet the TD way ! I still wonder about the d**n doors as well ! :(
GeekFisher
Images: 61
Re: The Geek's Lair
Postby twisted lines » Wed Feb 20, 2019 5:10 pm
GeekFisher wrote: Im reading stuff about building cabinet the TD way ! I still wonder about the d**n doors as well ! :(
I am cutting one piece at a time for the doors :roll: Yesterday it was for the rear door and today I wondered if the roof would fit in!
For now Im going to forget I read cabnet above.
twisted lines
Users browsing this forum: No registered users and 69 guests
