Truck Canopy Trailer - Updates... Solar Panel, Jack, etc.
Postby Jst83 » Fri Nov 25, 2011 9:46 am
My 7 year old summed up your camper in 2 words while standing here just now. Ooooooo nice and I'll second that :thumbsup: very clever
Jst83
Images: 215
Postby vwbeamer » Fri Dec 09, 2011 4:13 pm
Sweet, did you ever find out the weight? :)
vwbeamer
Postby ohbugger » Mon Dec 12, 2011 3:37 pm
- Deleted Post -
- Erik -
ohbugger
Postby ohbugger » Mon Dec 12, 2011 10:42 pm
Just got the trailer weighed tonight. 840 pounds! I was worried about creeping up toward the 1,000 pound mark.
I'm happy with the weight considering it's a 6'x8' and it has nearly two layers of flooring when you consider the bed is 5'9"x6'4" of 3/4" plywood and 4" of foam.
- Erik -
ohbugger
Finished!
Postby ohbugger » Mon Dec 12, 2011 11:34 pm
Well ok, I've got to make the window coverings and finish the little shelves in the rear under the outlets. But I'm calling the thing finished!
The bearings are freshly regreased and the trailer has been weighed. It's time to reclaim my parking spot in the garage.
Here are a few pictures of the electrical system which was the last major thing to get wrapped up.
Put the wiring in a cheap-o toolbox to clean things up and to be safe. That's a GFCI outlet that feeds the two other outlets to keep everyone safe!
The toolbox is pretty empty, if I replace the battery, I'll get something slightly smaller that will fit inside the toolbox. The current battery is 18 amp hours, but it really only feeds the led lighting and 2 12volt outlets, so hopefully a 10 amp hour battery will be enough and fit inside the toolbox
A battery charger is kept plugged into the outlet to keep the battery topped off.
Each side has a 12 volt outlet and a 120 volt outlet fed from the GFCI. This side includes the voltmeter which is switched on/off with the button next to the 12 volt outlet.
On the passenger side, the button is the on/off for the overheard lighting, and the knob below is a dimmer.
Cup-holders... vital.
Threw some carpet on the door to protect it and dress it up a bit, also carpeted where the old third brake light was.
Finally, the portable sound system. 2 - eight inch door speakers, a highly efficient digital amp, and a lithium-ion 12volt rechargeable battery in a custom made enclosure will rock out the camp site for 2-3 days on a charge. Something I made last summer that far exceeded my expectations. Had to show it off here as it is made for camping.
EDIT - I finally created a write up on the boombox / portable sound system http://www.tnttt.com/viewtopic.php?f=30&t=50238 Check it out!
- Erik -
ohbugger
Postby jonnyo » Mon Dec 12, 2011 11:39 pm
very cool trailer! look clean and well done! when is the first trip?!!!
jonnyo
Postby ohbugger » Mon Dec 12, 2011 11:43 pm
jonnyo wrote:very cool trailer! look clean and well done! when is the first trip?!!!
Thank you very much! I've been following your cargo trailer modification, very cool as well.
First trip? I might wait for it to warm up a bit? Or maybe not ;)
- Erik -
ohbugger
Postby starleen2 » Mon Dec 12, 2011 11:52 pm
Warm up?? I bet you could heat that thing with a hair blow dryer :lol: Nice build :applause:
starleen2
5th Teardrop Club
Postby Woodstramp » Tue Dec 13, 2011 3:07 pm
Erik,
Where did you get those fold away cup holders? I need some of those.
Woodstramp
RE: Finished!
Postby mezmo » Tue Dec 13, 2011 8:48 pm
Hi Erik/ohbugger,
Congrats on finishing the project! It looks sharp, and has such a high
level of finish!
Call it "The Splendide", as it turned out slendidly!
Norm/mezmo
mezmo
Images: 194
Postby ohbugger » Wed Dec 14, 2011 2:34 pm
Woodstramp wrote:Erik,
Amazon.com cheap! (free shipping with Amazon Prime, I get a lot from them now that everything I order has free 2-day shipping)
http://www.amazon.com/gp/product/B000Q8 ... 00_details
- Erik -
ohbugger
Re: RE: Finished!
Postby ohbugger » Wed Dec 14, 2011 2:36 pm
mezmo wrote:Hi Erik/ohbugger,
level of finish!
Norm/mezmo
Thanks for the compliment! Maybe I'll let my wife name it. She did spend the whole fall alone in the house while I was in the garage. She's glad I'm back inside during the evenings!
- Erik -
ohbugger
Postby vwbeamer » Wed Dec 14, 2011 4:39 pm
To be honest, when I started reading your thread I had my doubts, but this has turned out very nice.
You did a great job planning it and executing the build.
Thanks for posting the weight.
vwbeamer
Postby ohbugger » Wed Dec 14, 2011 7:48 pm
For those of us who tow with an unapproved vehicle. Here's a little info that helps.
I drive a 2008 Scion XB:
It is rated to tow... NOTHING.
The same car in Australia is called a Toyota Rukus:
Same engine, same tranny, same darn car is rated to tow 500 kilograms (1,100 pounds) by Toyota. Perhaps the Aussie version has a tranny cooler, but I doubt it.
Anyway, there you have it.
- Makes me feel good about the 840 pound weight I ended up with! -
- Erik -
ohbugger
Postby 2bits » Thu Dec 15, 2011 12:14 am
Trolling through the build threads and I saw your build!
I have seen s few camper tops on the back of a truck bed, but building your own trailer and lower shell makes it match so much better! Mine is more than a toppper, but less than a cabover but it is so tall it unnerves me with the wind hitting it, so I might consider this.
I built an awesome teardrop, and decided to sell it for some land when I found this for $150 which is very similar to yours.. I also got it for $150, but it is alot more old school than yours. I think the defining factor is the complete rear section with the entry door, that separates them from a campertop to a camper...
Really nice work on the conversion!!! Here is mine:
Thomas
2bits
2bit Member
