A crisp fall day in Wisconsin and I got some more work done on the tear. I had already traced the outlines onto the insulation before I attached it to the cedar boards, and I just used a jigsaw to cut out the foam for the inner wall. Here is the wall without the insulation.
As you can see, the pink panther insulation is slightly thicker than the 1/2" wall, so I'll need to do some "shaping," like a surfboard. Now that I think of it, my biggest project I've ever done from scratch before this teardrop was shape and build my own windsurfing board. There was a LOT more foam to be removed on that project.
Using a surfoam, I took enough material off so that the insulation would be flush. I also placed some pull wiring through the gap so that I can easily get the wiring for the marker lights.
What's a surfoam you ask??? Think of it as a cheese grater, but for foam. I have a couple of these from my windsurfer project, and they still work like a charm.
Foam in a can was on sale today for $2.99 at the local True Value, so I scored a few cans. I filled the gaps between the signboard and the insulation. Should be air tight, and ready for the outside layer.
