capnTelescope wrote:Hey, PubUltraStar. Glad to see you're back in action. I'm looking forward to more of your awesome build.
HarryL wrote:...I've been wondering when you would be getting back to your Explorer build. Your floor system seem ingenious!
Chinookered wrote:I'm sorry to hear about the MS. I can hope and pray that the medication you are taking helps in many many ways.
Chinookered wrote:After reading your last post about your AC unit needing line of sight for the remote a thought came to mind. Is it an IR remote? Why not use an IR repeater like some hidden AV components do?
PubUltraStar wrote:Great idea, as I had already toyed with that same concept, mainly because I would want to make changes to the temperature from inside the teardrop without getting out. Inside the tongue box, I don't care what it looks like, but inside the cabin, I'd want it to be integrated into the design without looking out of place.
PubUltraStar wrote: As far as a door, I planned on putting a hatch door anyway to provide visual to the display LED, as well as a bit more ventilation. There will be other vents on the sides, but want to keep it minimal. I think that opening up the lid might be the best way to ventilate while on-site.
Chinookered wrote:Are you separately ducting the exhaust from the unit as well as the intake? Or just opening up the lid and hoping its a large enough flow of air to do both? Also, if you keep your battery there, are you worried that someone may come along at night and remove items from your tongue box while the lid is open to ventilate?
