JmsCaverly wrote:I just weight it and it's at 13.5 lbs give or take a bit. Not very heavy but solid.
Thanks that gives me an option.
lfhoward wrote:Disclaimer: I have never built a hatch or bent aluminum along a curve.
But I agree with you, I think option 1 would be best. I think I've seen some folks heat up the aluminum to make it pliable. There is a term for that process that I'm not able to remember. But somebody might know what it is and point you in the right direction.
badschnauzer wrote:Why put any T or angle trim along the edge? It looks like you have a tight fit with good gasket compression. That alone should prevent water from entering the galley. Of course, if you are skinning the hatch top with aluminum, you'll want some thin c-channel trim for appearances sake. Just a thought
badschnauzer wrote:We are at the exact same spot in our builds. I applied my outer hatch skin last night and started building one of my doors today while the hatch adhesive set. For my hatch, I ran the ply over the sides, like you. I will add another ply strip along this edge for reinforcement. Then I'll run my PMF canvas from the top, around the edge and under. Should make a watertight seal with the D style compression gasket.
vegask wrote:I also have not built a hatch but I did sleep in a holiday inn express the other week...
aggie79 wrote:It's hard for me to tell from your pictures, but it looks like you used some type of aluminum sidewall edge molding in front of the hatch. Why don't you use the same for your hatch?
I wouldn't worry about the lower leg being long enough. It doesn't provide much waterproofing anyway. With your double seals at the hatch and the "rain gutter" space between the seals, I don't think you'll have to worry about water intrusion. (I used a similar double seal on each side of my hatch. It has been through several downpours while in transit and at campgrounds and has never leaked.)
badschnauzer wrote:How much overhang should I have on my hurricane hinge? Is 1/2" enough? What's the standard?
ELM wrote:Hi your teardrop is looking great. Here's a few you tube videos I found on annealing aluminum https://www.youtube.com/watch?v=GEKE9AOdXO4
https://www.youtube.com/watch?v=EzhnZemxJ1c
