Last month I took a quick trip to the Cuchara, CO area. This was the disaster that always sits around the corner. To start our conversation, here is the good.
- IMG_0060Small.jpg (94.35 KiB) Viewed 375 times
Rather then spend the twenty some odd dollars a night to stay in the campground, we opted to go up the mountain a bit. The road was very rough so I pulled off at one of the switchbacks. The site was pleasant and the sound of the stream below was relaxing. I put up the tarp since it was supposed to rain. It is a Slumberjack Roadhouse tarp that was designed to hook to the wheels and provide coverage out the back of a SUV. Since I rarely sit behind teardrop but off to the side, I cut a piece of EMT into three sections and when I got to site, put the sections together with couplings, attached the vehicle side of the tarp to the conduit and tied it off to the wheel and the frame at the front of the tear. It worked well, but I think it would have worked better if I had a roof rack to attach it to. That's the good.
Now for the calamities. First, I was looking in the mirror and noticed my fender shaking more than usual. At the rest area, I checked it and noticed the weld attaching the bracket had cracked. I didn't think it was going to be a problem but I was wrong. The fender came off just before I got to the road that I went up to camp. Here is a picture that we took when we got home.
- Missing Fender Small.jpg (51.51 KiB) Viewed 375 times
Having never welded before building the trailer, I shouldn't be surprised that a weld failed. If it is the only one that fails, I will still consider my welding successful.
The next issue that we had was the site was so sloped that we could not get the trailer level front to back or left to right. Since the back was higher despite a 4x4 and 2" flat rock under the tongue jack, we slept with our heads at the foot of the bed by the bulkhead. To sleep under the covers, we pulled the sheets up and found they were wet. We found that the water had leaked from the water container and passed under the bulkhead. I came home and, doing some research, found John's, Capebuild's, post on "leaking water jug spout." He showed where he found his spout leaked and I figured that's where mine was leaking. I have received a similar hose bibb valve and will at some point put it together. Further thinking about my leak problems, I wonder if the problem stems from the fact that I fill the water container at 3,600 ft and park at 9 or 10,000 ft. The difference in pressure between the inside of the container and the atmosphere forces the water out through the spout where John shows the leak. Hopefully the valve will keep the water in the container and not on the floor of the trailer. Just in case though, I caulked the floor/bulkhead seam as well.
The final thing that hit was leaving the site. The road was so rough that the bolt on the positive battery terminal came undone. The battery cable came lose and, I guess, shorted out the battery monitor. The monitor has now been replaced. In the future, I need to check the tightness of those bolts before I take off each time
I have all the parts necessary to put a fender back on the trailer. Hopefully, I will get this corrected by the end of the month so that I can head out one or two more times before winter sets in.
One more thing.
orourkmw wrote:Since I have started on my teardrop journey, I keep my eyes peeled on the road for home-built teardrops. On this last trip, we drove all the way from Louisiana, to New Mexico, and up to Colorado, and home, and only saw two. And those were both really ragged square-drops...I think it is unlikely the owners show their pics on this forum...
I just took a trip to Colorado last week and noticed the number of large trailers and fifth wheels. I got to thinking what happened to the smaller trailers. Even the small trailers have slideouts. I only saw a couple popups. Teardrops really surprised me. I saw two on the way up. One between Amarillo and Colorado Springs and one between the Springs and Fort Collins. The surprising thing is that since I only saw the first one from behind, it looked like the same tear. Coming home from Ft Collins to Amarillo, I saw 3 and one of those was really rough. Now for the big surprise. Driving between Laramie, Wy and Ft Collins, about an hour's drive, I saw 3. Did I see a migration to Walk the Winds?
That's what I have for now.
