Torpender Build Thread: Update - campin'
Re: Torpender Build Thread
Postby mikeschn » Wed May 29, 2013 6:59 pm
fartblossom wrote:Installed axle, springs and wheels today. If I'm overposting, just let me know. :)
Are you going to cut the vertical angle off???
Images: 479
Postby fartblossom » Thu May 30, 2013 7:35 am
well..... it would have been a HELL of a lot easier if I had done it before I bolted the trailer together...
Now I can't get an angle on it with my reciprocating saw. Maybe I'll try a cutoff wheel instead.
My build thread
viewtopic.php?t=55238
fartblossom
Postby fartblossom » Mon Jun 03, 2013 12:53 pm
Well, had to help move my son this weekend so didn't have the time I wanted, but managed to get the floor sides coated.
Used rustoleum undercoating.
My build thread
fartblossom
Postby fartblossom » Thu Jun 06, 2013 3:44 pm
Cut my first radius last night.
Had some "in and out" on the lower section, but got my technique down for the longer upper ellipse. Now to lay this piece on top of the other side and transfer the curve.
My build thread
fartblossom
Postby fartblossom » Sun Jun 09, 2013 2:27 pm
Gentlemen, we have PROFILE! Now I feel like I'm actually accomplishing something.
Transferring profile to 2nd side piece.
Undercoating the bottom of the side pieces before attaching to trailer
Up and ON!
First look at the full size deal.
Next up, cross pieces and door.
My build thread
fartblossom
Postby fartblossom » Sun Jun 23, 2013 12:12 am
Got the rear galley wall perimeter framed and a couple of front cross pieces in today. Will be going with 8" on centers through the radiused area.
My build thread
fartblossom
Postby fartblossom » Sat Jul 06, 2013 11:57 am
Got the majority of the crossmembers done, and started bending the roof ply to shape. I strapped it and bent it a little, then waited a few hours to allow the fibers to stretch, and tightened again. Tomorrow I will attach it permanent. Using 5mm underlayment from HD.
Got the door cut out, used the dimensions of an aftermarket door,http://bit.ly/13ASmA4 just in case I can't get a home built door to work, then I can just throw money at the problem to make it go away.
And before you ask, no, I'm not doing an interior ceiling. I might at some point put some coroplast or even a reed rollup window shade ceiling but for now, I'll just enjoy the woodgrain and do some sort of varnish.
My build thread
fartblossom
Postby rebapuck » Sat Jul 06, 2013 11:27 pm
I like it. Good thinking on the door plan.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby fartblossom » Sat Jul 13, 2013 2:59 pm
O.K. Mike, you happy??
Image :D
Got 1/2 of the curved sheet of 5 mm glued down today, and chopped off the offending caster flange on the trailer. Will finish the gluing of the rest of the sheet tomorrow morning and maybe do a little priming.
My build thread
fartblossom
Postby fartblossom » Thu Jul 18, 2013 5:31 pm
Once the late July and August heat arrives in D/FW it's impossible to work more than 30 or 40 minutes in the garage, so my goal till September is to just do one thing each day. Today I just installed the last crossmember. Yesterday I installed two skin panels. The day before I glued down the front radius skin.
One day at a time.
My build thread
fartblossom
Postby KCStudly » Thu Jul 18, 2013 6:45 pm
Plug and chug; the train kept a rollin'. :thumbsup: :applause:
Drink lots of water. :D
Postby fartblossom » Fri Jul 19, 2013 4:52 pm
KCStudly wrote:Plug and chug; the train kept a rollin'. :thumbsup: :applause:
Chugging along, KC. Added two new crossmembers. These are to give blocking for shelving in back wall.
I'm thinking of renaming this the "Kreg Special" since I must have a least a jillion kreg connections at this point.
My build thread
fartblossom
Postby fartblossom » Sat Jul 20, 2013 8:48 am
Experienced my first "built something in the basement and can't get it out" moment today. Had to take the top piece of blocking out in order to get the inside sheathing of the backwall into the trailer. DOH! :oops:
My build thread
fartblossom
Postby fartblossom » Sat Jul 20, 2013 7:40 pm
First piece of FRP done in the kitchen, annnnnd DONE for the weekend.
My build thread
fartblossom
Postby fartblossom » Sat Jul 27, 2013 11:38 am
Was planning on doing all sorts of things this morning, but all I managed to do before it got too hot was finish the frp in the galley.
I'm planning on using this channel to cap the top of the wall at the hatch area.
It's an aluminum channel used in installing stretchwall fabric. Came out of the extra bin in our warehouse. Worked out perfect for a 1/2" wall with a layer of frp.
My build thread
fartblossom
