Trailer for Lost Hikers
Re: Trailer for Lost Hikers
Postby Shadow Catcher » Mon May 05, 2014 6:58 am
If you plan on off road travel, or even if you do not you need brakes.
Postby hiker » Tue May 06, 2014 6:41 pm
119919
Trailer basement compartment insulated and floor almost complete.
Build Journal: Expedition Trailer Mk I http://www.tnttt.com/viewtopic.php?f=50&t=57985
hiker
Images: 41
Postby hiker » Tue May 06, 2014 6:42 pm
119920
Trailer floor is complete!
hiker
Images: 41
Postby hiker » Tue May 06, 2014 7:21 pm
119930
Max Headroom check, from the absolutely bare floor. With a five (5) inch mattress leaves me three (3) inches to spare.
Any thoughts?
hiker
Images: 41
Postby hiker » Tue May 06, 2014 7:25 pm
119931
What is inside the front wall?
The outside face is 3/8" plywood, with 1x2 studs separated by 3/4" Owens Corning FOAMULAR® 250 Rigid Foam insulation, 1/4" plywood inside face.
hiker
Images: 41
Postby hiker » Tue May 06, 2014 7:31 pm
119932
Front wall inside view before it is sealed from view forever.
hiker
Images: 41
Postby hiker » Sun May 11, 2014 8:25 pm
120108
Cleats for attaching the walls and floors.
hiker
Images: 41
Postby hiker » Sun May 11, 2014 8:29 pm
120109
Cut outs for the windows. Cut all 4 walls at once.
The windows are 6" x 8" two per side. The windows should be eye level when sitting inside the trailer.
These are to be Wiley windows. I wish I could find the metal frames for the Wiley windows.
hiker
Images: 41
Postby hiker » Sun May 11, 2014 8:31 pm
120110
Inner walls and outer walls cut for Wiley windows. The trailer front on left of photo.
hiker
Images: 41
Postby hiker » Sun May 18, 2014 4:38 pm
120306
An outside view of the first wall are up. The front wall is attached to the left front side wall.
hiker
Images: 41
Postby hiker » Sun May 18, 2014 4:39 pm
120307
An inside view of the first wall are up. The front wall is attached to the left front side wall.
hiker
Images: 41
Postby hiker » Sun May 18, 2014 4:54 pm
Shadow Catcher wrote:If you plan on off road travel, or even if you do not you need brakes.
hiker
Images: 41
Postby hiker » Mon May 19, 2014 6:39 pm
120386
Front wall, left and right forward walls, and roof spars #2 and #3 are in place.
Glued down insulation for left side rear wall.
Getting measurements for rear lights.
hiker
Images: 41
Postby hiker » Sun Jun 08, 2014 6:10 pm
121247
Shelf and right rear wall glue drying.
hiker
Images: 41
Postby hiker » Sun Jun 08, 2014 6:13 pm
121248
Right rear wall and interior wall with shelf are up.
hiker
Images: 41
