First build. 4'x8' HF Teardrop (Lots of photos)
Re: First build. 4'x8' HF Teardrop (Lots of photos)
Postby Kullas » Mon Mar 17, 2014 8:56 am
Coming right along. you will be sleeping in it by spring
Chris
Kullas
Postby Swank1975 » Thu Mar 20, 2014 10:18 pm
Today I got the 1/4" sanded ply for the headliner. I am a bit frustrated it did crack in one spot. I glued it all and used brad nails to secure it until dry. The good news about the crack location is it is actually inside one of the cabinets I am building in the interior.
My wonderful crack. Sigh
Roof with roof vent framed.
Inside shot
Swank1975
Postby jbyrd » Fri Mar 21, 2014 8:57 am
Looking really good so far! I know those cracks can be very discouraging.
It happened to mine on my first build but i was able to sand it down and
fill it and paint it, you couldn't even tell it was there after.
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Postby tac422 » Fri Mar 21, 2014 10:16 am
You could glue a piece of plywood to the back side to strengthen and get the correct curve .... :thinking:
Screw a piece of wood across the ribs with a brace between the wood and the added piece until it dries ....then remove the brace and the wood.
tac422
Postby Swank1975 » Fri Mar 21, 2014 10:28 am
Thanks for the tips. I will test fit the new cabinets inside and see what the finished results will look like and go from there.
Swank1975
Postby Swank1975 » Sat Mar 22, 2014 6:27 pm
Cut the door shape out today.
Swank1975
Postby Swank1975 » Sun Mar 23, 2014 5:16 pm
I currently have a home made steaming tent running in the garage. It involves saw horses, a tarp, some styrofoam insualtion, 2 pots of water, and a camp stove. Pics to follow.
Some of the steaming guides I have seen said 1 hour of steam per inch of wood so i'm guessing 15-20 minutes for this 1/4" piece.
Wish me luck.
Swank1975
Postby Swank1975 » Sun Mar 23, 2014 7:12 pm
Well it did crack a little but I can work with this.
Swank1975
Postby Swank1975 » Sun Mar 23, 2014 8:25 pm
Preview of the hatch in place.
Swank1975
Postby jbyrd » Sun Mar 23, 2014 9:16 pm
starting to come together, looking good!
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby Swank1975 » Fri Mar 28, 2014 5:04 pm
Dying to go get more lumber to keep going.
Swank1975
Postby Swank1975 » Sun Mar 30, 2014 2:50 pm
OK Time for an update. Got some wood and stuff and got most of the galley built.
Swank1975
Postby Swank1975 » Sun May 11, 2014 8:01 pm
Finally time to update my build some.
I have ran wires, test mounted the hatch, insulated the voids, and put the 1/4" AC ply on the outside. Now I need to get my aluminum skin so I can keep this project going.
Swank1975
Postby ctstaas » Mon May 12, 2014 12:51 am
Lookin good! One thing you might want to consider on your spars. I set my spars into the plywood, meaning i cut a slot in the edge of the walls to fit the spars into. I only used three for the whole roof. Insetting them gives them more purchase, meaning there is more surface area of the spar contacting the wall thereby giving more strength. The strength of your joints is limited to sheer strength of the screws. If you changed out three maximum the strength would be increased a lot. Something to think about before the roof goes on.
ctstaas
Postby StockCube » Mon May 12, 2014 4:24 am
I am a bit late to this party, but just thought I would mention that I ran a wallpaper steamer inside my cabin while I was fitting my interior curved ply and it worked a treat.
StockCube
