Thanks for the picture Frank, will see how things go when I get there. Not going to be too soon at the pace I'm working. So you didn't use any plywood for an underlayment for the skin, just the aluminum?
Back at it again this morning. Started locating things a bit more, worked on the bumpers, latch mechanism & strut attachments. Here's the latch block, 3/4" plywood with "T" nuts to hold the 1/4" bolts. I counter-bore the back side with a speed-bore bit to set the inserts flat to the block & flush so the 1/8" goes on without any lumps when it's time to do the plywood skin.
After things are located, I mix up some 5 minute epoxy to pot the inserts & make sure they stay put once things go back together again. Screw it all together & let it sit, all set in no time in the heat! Have to work fast and have everything mapped out or the epoxy kicks off too fast and I run out of time.
Same thing for the strut braces. All of this will be glued in place with titebond for the final assembly, but as I said, it's all just a dry fit for now to check things & locate all of it first. The last thing I need now is to get out of sequence on something at this point. It's enough work without the mistakes.
Here's the hatch now with a few more things in place. The bumpers are located, but I still need to pot the inserts once the hatch is out of its opening. For now just a few drywall screws are holding them in place in the pilot holes. The latch handle is located, but I will still need to drill for the rods & cut them to length so they extend into the sides when they lock. With this latch type, the rods travel about an inch with a 1/4 turn of the handle, so I'll have about 5/8" engagement on both sides, which should be plenty for what I have. I may leave the rods out about 1/8" if the hatch doesn't have any twist when it's done, so there might be more like 3/4" of grab into the sides.
What's left still in the hatch framing department? Need to do the blocking for the back-up lights. They will be above the bumpers and routed into blocks. Need to make a jig for the cuts as I'm using a reverse flush cut bit & the plunge router. Stereo speakers will need enclosures which hang down from the inside the hatch and miss the cabinets, struts, etc. Galley light blocking, license plate blocking & paper towel holder all need to be located. Wire runs & grounds will need to be located as well, so I'm not there quite yet. All in all it was a good weekend of work.
