Finally, blue skies & the heat's back again! Did some more work this morning on the hatch. I've added a 1/16" filler strip to the top edge on the front side, as it was a little sloppy when the hinge went in place. With the high humidity these last few days, the hatch did swell a little bit, but nothing bad. It didn't get wet. Time for the outside hatch skin.
Since the hatch & body are both oversize by 1/2" (60 1/2" due to the frame size being slightly over 5' wide), I decided I would just use 2 sheets of 1/8" BB & do it in two halves instead of one entire sheet. Figure I will use the material that's cut for something sooner or later. I wanted to make sure the fit is right before the aluminum goes on. I don't mind having a 1/4" void under the trim where the aluminum is short along the edges, but I do want the hatch build-up to be right underneath it for support of the metal when it goes down & gets glued along the edges. With 1" wide aluminum trim & a good bedding compound, it should be fine once the skin & trim are all buttoned up.
Here's the first half glued & stapled in place.
Here's the full skin in place & the back-up lights routed out. Progress!
I have a question I've been pondering for a while & would like some input from those who have faced this decision already & have seen how it worked out.
I need to drill the two latch rods in the side of the body, where they engage when the handle is turned & in the "closed" position. I'm trying to decide if it would be better to mount the hinge, mount the struts & then drill for the rod holes, or wait until the gaskets are all in place before I drill for the actual closed position on both rods. I'm fairly confident that I have a good fit & uniform gap around the hatch at this point, but I'm wondering if a hollow gasket will have that much resistance and make closing the hatch a PITA if the gaskets don't compress very easily.
The gaskets are the 5/8" X 0.40" hollow type & will have to compress down to .31" on the bottom edge & about 1/4" along both sides. They seem fairly soft & compress very easily between two fingers, so I'm not sure on this one. Appreciate your input on this question. Thanks, tim
