It's been a while since I posted progress. Yard work kept getting the way.
I came up with a solution for latching the tail gate to the trailer. Around a year ago a friend was having his windows replaced and I aquired the old ones. They have two sash locks and a crank out mechanism on them. Decided to use the sash locks for the tail gate. There are two on each side. I may add two more on the floor about 4 inchs out from the wall. Anyone got any ideas on what I might use the crank thingy for?
Then I started on the roof. I cut out all the frame pieces by ripping 2X4s.
This shows the overhang the roof will have at the back.
Then I mocked up what the roof might look like open. Raised up 3 feet it gives 4.5 feet inside height.
This shows how much eve overhang the roof will have at that height. I could go higher but I sort of like having the eve sticking out there. I might cut it off after hitting my head on it a few times.
Laid a untouched sheet of ply down on the frame members doing a dry fit.
Discovered the box is out of square by about a quarter inch. Not sure you can see it in this picture. I don't know what I was thinking, I always check drawers for square before I glue them up. I might trim that off with a flush cut router bit later, or leave for discussion.
One full 4X8 installed on the frame members.
This shows the seam reinforcement I used. Better than nothing. Should help hold that seam straight and tight. I thought this approach would be fairly light.
And now I have a finished roof.
Next will be back wall and door with the roof in the up position.
