Torpender Build Thread: Update - campin'
Re: Torpender Build Thread
Postby fartblossom » Sat Aug 10, 2013 5:10 pm
It's just too stinking HOT to do much, but I managed to get a little painting done.
deck o' cards paint shielding shamelessy stolen from another thread. I'd give credit but I can't remember whose.
My build thread
viewtopic.php?t=55238
fartblossom
Postby rebapuck » Fri Aug 16, 2013 10:47 pm
Good idea. Paint something else. Then something else. It'll get done.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby fartblossom » Sat Aug 24, 2013 10:43 am
Thanks for the encouragement rebapuck.
Put the hitch on the car this morning, and primed/sealed the passenger side of the trailer with Kilz. After which my wife had the audacity to describe my smell as "ripe". How rude.
My build thread
fartblossom
Postby fartblossom » Sat Aug 31, 2013 1:12 pm
First coat of Hunter Green rustoleum oil-based.
My build thread
fartblossom
Postby rebapuck » Tue Sep 03, 2013 11:12 pm
Oooh. Looks like my Velvet green VW.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby fartblossom » Mon Oct 07, 2013 7:19 pm
Finally! Cool weather. Getting back in gear.
Finished painting of both sides for now. May put another coat on later.
Drug the old Pontiac Aztek air mattress out of the attic and it fits like a glove.
Laminating the FRP skin. Even though this FRP is supposedly "Silver", it's way too white. Will try some of the spray for the trailer on it but will probably need to roll it with silver at some point.
Looking forward to showing you the flexible trim I found for the edge of the roof next. It may be the only real contribution I ever make to this forum.
My build thread
fartblossom
Postby Junkboy999 » Mon Oct 07, 2013 10:37 pm
Looking great so far. Man that is gonna be one huge galley.
For the trim are you talking about the Pcv style window trim? Someone a few months ago use it and it looking good so far. still waiting to see how long it holds up.
Junkboy999
Images: 52
Postby fartblossom » Tue Oct 08, 2013 8:16 am
This is the stuff. http://trim-tex.com/product_catalog.php?cat_display=showproduct&id=161
One leg of the plastic angle is 'rubberized' for lack of a better word. It bends around really tight curves with no buckling or stretching, no heat gun necessary.
I'm going to do a separate post on it with pics and more details, plus where to find it later today in the tips section.
My build thread
fartblossom
Postby fartblossom » Fri Oct 11, 2013 4:53 pm
Putting on the first piece. If you look close, you can see how the shorter leg is attached to the larger.
Adhered using PL.
My build thread
fartblossom
Postby fartblossom » Sat Oct 12, 2013 11:21 am
Tape off, both sides done.
Rear shelf in pantry ready for 5mm ply
with ply
ready for frp
weighted with some oil I need to get to the recycler, and clamped
My build thread
fartblossom
Postby fartblossom » Sat Oct 26, 2013 4:49 pm
Mitered a frame for my removable kitchen counter. There are some screws beneath it blocking it from dropping through.
My mascot, Spidey.
Decided to use the last of my titebond.
dropped piece of 5mm on top
Then used screws to suck up frame to plywood
How it looks from underneath.
My build thread
fartblossom
Postby fartblossom » Thu Oct 31, 2013 6:20 pm
Got the aluminum edge trim on the galley and started the hatch framing.
Perimeter of hatch is done! All infill from here.
My build thread
fartblossom
Postby Ron Dickey » Thu Oct 31, 2013 8:44 pm
great job looks like you know what you want.
you might add what you did to this site I put up as I built my HF
Harbor Freight trailer questions and answers
viewtopic.php?f=35&t=54757
Ron
121377......134179
Ron Dickey
Images: 711
Postby fartblossom » Thu Nov 21, 2013 3:24 pm
Thanks Ron, will do.
Life has been scheming to take up all my time lately, but I managed to get a tiny bit of hatch framing done today. Hope to have more time over the holiday.
My build thread
fartblossom
Postby Junkboy999 » Sat Nov 23, 2013 10:05 pm
You need to keep us posted on how that trim works out. As long as the sun does not destroy it, it look like it might be an easy way to go. I know the LP should hold it along it length, but I just wondering about the very bottom. Turbulence from the car and trailer might work that bottom corner loose and allow the whole thing to fly off. Just thinking out loud, but I is there any way to secure just that lower front part so it will not work loose?
Keep up the good work. :)
Junkboy999
Images: 52
Users browsing this forum: Bing [Bot] and 14 guests
