Well I have gotten a lot done so far this month. My fiancee and I have decided to take a 4 day mini-moon in the trailer after our wedding in October so I have a hard deadline to finish by!
This is going to be a long post so please bear with me! Lots of pictures..
Starting on the bulkhead. I am using the same sandwitch method as the walls.
Testing out the bulkhead fit after gluing on one of the skins.
Just cut out the counter!
Got Clamps??
Shaping the top of the bulkhead to match the roof liner. Decided that it was best to use a circular saw with a fence set at 18 degrees. This was definitely a daunting cut.
Looks like the bulkhead fits! I still plan on pulling it out later to finish the surface.
This is how Im getting the wires from the battery to the roof.
Working on the floor that covers up the rear hatch in the cabin. Again, the same construction method as the composite walls.
Here it is installed. I used a 48" piano hinge on the back and flush mount rings for the handles.
I am using a WFCO 35 amp power converter to charge the battery and provide 12v when on shore power. I decided to make this little power center in the corner below the galley cabinet to hide the mess of wires that is bound to happen.
Working on the galley cabinets. I am definitely getting good at using the pocket screws at this point.
I was daunted about the idea of making this sliding compartment. I just went for it and it worked great!
The galley cabinets are snug, but thats what I wanted! This is my first time doing any sort of cabinets. I was very pleased with the results!
Working on the cooler slide that will reside under the galley counter. I plan on this Yeti 50 quart cooler lasting forever, and I basically designed the trailer around it..
Constructing the slide out stove/ storage cabinet that will mirror the cooler.
Looks like all fits! Im not going to know what to do with all of the extra space. I spent way too much time figuring out where to store my beloved cast iron griddle. I fashioned the cabinet so that it can slide in just under the stove for storage.
I had to do a little fixin to the the stock coleman propane attachment.
With less than 1/4" clearance It is definitely a tight fit back there! The optima battery will also slide behind the stove cabinet.
Working on the cabin cabinets. I routed the bottom of the face frame smooth so that it wont hurt as bad when I hit my shins on it.
Testing out the face frame in the cabin.
I still have more work to do on this but at least it fits!
