halfdome, Danny wrote:Years ago on This Old House it was said drilling a hole through a supporting member cuts the strength in half so I only drill one hole for the roof fan.
twisted lines wrote:Power the brown post when disconnected from Auto power, your detail may like the all red function at camp or roadside
twisted lines wrote:Yes in the cabin preferred
Trim / clearance / marker / tail / brown / tan ,,,,,, pick one.
I figured you had it
western traveler wrote:twisted lines wrote:Yes in the cabin preferred
I understand you two are talking about a switch to use clearance lights for campsite lighting, Is that correct? I am clueless and hadn’t heard of or seen it. Is it common? Can you explain this in simpler terms. How does a person add a separate switch to turn them on?
halfdome, Danny wrote:I run power from my fuse block
