My Jeemper
Re: My Jeemper
Postby Rogheff » Sat Jun 12, 2021 9:19 am
I’ve had a busy couple of days. After insulating my walls, I clad the inside with pallet wood.
165975
I then found the best spot for my “icebox” it is actually a Coleman cooler that functions as an icebox.
165977165978
Then I got ambitious as I was sitting in the camper enjoying the cool breeze on my legs and positioned two of my cabinets. The cabinet closest to the door I see my “everything” box that carries my essentials for camping (you know, plate, cup, spoon, humidor, spices, flask, etc.). The skinnier box is one that I just picked up. It will cover my air conditioner which will protrude about 6” out right over the drivers side fender.
165976165981165982
Finally after spending a couple of days working on the inside, I fleshed out my bed/ upper floor concept. I am going to go with a tri fold sofa bed, similar to the sofa bed that Vistabule uses. I really like sitting in the front of the camper relaxing after building all day and dangling my feet. Having a 5’ sofa folded during the day, leaving the 5’ standing room opening, seems to be just right. The more I thought about the construction, if I build it right and out of treated lumber, I’ll have a solid “floor” that covers the opening at night and while driving (completely weathertight and secured of course). Then I would just need a removable section in front of my icebox.
165983
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Sun Jun 13, 2021 3:22 pm
The tri folding sofa/bed/upper floor is done. It turned out pretty nice. It is constructed of treated 1x8s supported by 1x4s which glide in the center and outside edges on aluminum strips. It glides quite nicely. I have some finishing touches to do on the front where my legs will go. When it is in bed mode, it will lock to the frame to keep water, dust, and critters out while traveling. I have a 2x2’ area to finish with a removable section that will lock into the bed section. I borrowed some lawn chair cushions to test it out. They are not the final cushions.
166018166019166020
Tomorrow, I’ll start tinkering with the icebox area.
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Wed Jun 16, 2021 10:45 am
Today’s project was an ambitious one. I finished off the inside air conditioner. Naturally, it is slightly larger than advertised. It did fit inside my wooden box though. The outside view is far from finished. I’ll be building a diamond plate box to house it.
166041166042
Then turned to the removable floor. I already had the folding sofa/bed/floor, so installed the latch to suecure it while traveling. Then I created a removable section that locks between the sofa and the door.
166046166047166048166049
Finally, I completed the rear door.
166044166043166045
View from the inside in travel/sleep mode. Edited to add that the interior sleep space is about 4’-9” x 6’-3” or as the wife preferred “ how much elbow room will there be inside”? It also measures 4’-3” from the floor to the ceiling and 6’-3” from the ground to the ceiling. Talk about gaining head room.
166050166051166052
Rogheff
Images: 63
Re: My Jeemper
Postby QueticoBill » Wed Jun 16, 2021 2:07 pm
I think you did all this last year at a normal pace and are just posting now to make it look like very fast progress. :)
Impressive! At least I'm very impressed at the speed you are moving.
QB
QueticoBill
Images: 22
Re: My Jeemper
Postby Rogheff » Thu Jun 17, 2021 5:02 am
QueticoBill wrote:I think you did all this last year at a normal pace and are just posting now to make it look like very fast progress. :)
Lol, I am on a mission.
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Fri Jun 18, 2021 3:15 pm
I stained the inside today after taking the camper on a road test. It performed flawlessly. Honestly, I was a lot more concerned about the soft top than the trailer. Both Bestop and Softopper cautioned me about doing something to avoid a catastrophic failure. I did several things to reinforce the frame, then beefed up the front panel. It had no issues. Looks good behind the Jeep. It Sits a bit taller than I hoped, but had no drag issues in the wind. I didn’t even know it was back there.
166072166071
Here’s a question for you. I was originally planning to paint the whole thing red(except the topper). But the shiny aluminum is starting to grow on me. Plus the complexity of painting it and getting the paint to stick is making me hesitate. My current plan is the paint the corner trim red and leave the panels shiny aluminum. All shiny is too much I think.
Rogheff
Images: 63
Re: My Jeemper
Postby John61CT » Fri Jun 18, 2021 3:54 pm
All shiny looks great IMO
simplest easiest no maintenance too
John61CT
Re: My Jeemper
Postby featherliteCT1 » Fri Jun 18, 2021 5:58 pm
all shiny ... definitely! :thumbsup:
featherliteCT1
Re: My Jeemper
Postby Rogheff » Thu Jun 24, 2021 10:22 am
Wow, I thought that I had posted more recently. I did a lot of busy work on the Jeemper since my last post. I am taking your advice and keeping the Jeemper shiny aluminum, but still wanted a splash of color. I installed fold-down benches (in case there are no tables present), and the underside seemed like a good spot for color. They are made of trailer ramps. They are about the right size for a bench.
166150166151
166154166153166152
You might also notice in the distant photo, I had cobbled a tarp support. That is a work in progress.
On the inside, I found some cushions for the sofa bed, installed more storage boxes, stained everything, and started adding some necessities.
166149166147166144166143166142
I finished my under floor/ bench storage
166140166141166139
Finally up to this point, I made a fold up arm rest. The board was attached to a bare rafter in the roof of my home in Wisconsin. I believe it is the name of the builder from 1928. The whole inside has a dark wood/brass motif going on.
166146166145
It is now in “campable” condition.
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Mon Jun 28, 2021 1:35 pm
Today, I got the Jeemper weighed so that I can get it titled. It weighs in at 1020 lbs empty. I also have been tinkering with a brass water cooler idea.
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Sat Jul 10, 2021 11:33 am
I am on vacation and 1000 miles away from the Jeemper. I decided to try something different and make an emblem to attach to the door. It should look like a tire on my Jeep, I found a large copper plate and etched it. I can’t wait to get home and add it to the camper.
166397166396166395166394166393
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Sun Jan 30, 2022 8:16 pm
I thought that I’d post an update on my Jeemper. I’ve camped in it three times. It has about 500 miles on it. Two of the camping trips have been downpours, it rained the entire drive the first time. In both cases, not a drop got inside. Even with the open floor in “couch mode” at camp, it stays bone dry inside.
The fold down benches have been critical as I have yet to see a picnic table.
With internal bracing on the topper, it pulled down the road at 60mph without issues.
Two of the three camping trips have been at or near freezing. It’s cold at night. I need to get a small heater. I’m thinking propane as only one trip had electricity.
All-in-all, it performed flawlessly. Was roomy and comfortable at night in “bed mode”. Roomy and convenient in “couch mode” during the day. I love it. Thank you tnttt community for the inspiration.
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Sun Jan 22, 2023 7:00 am
UPDATE:
I added lights to my Jeemper
Rogheff
Images: 63
Re: My Jeemper
Postby Rogheff » Sun Jan 22, 2023 7:02 am
Ok, how I get the video to actually show?
Rogheff
Images: 63
Re: My Jeemper
Postby Capebuild » Sun Jan 22, 2023 8:14 am
I believe once you click the "YouTube" link in the above menu bar and you paste your YouTube link in place you then remove the portion in yellow (shown in the attached photo (leave the semi colon at beginning of "https"just after "YouTube" and (I think) you remove the slash just before your C2z (etc.). Best to do a preview and make sure this is correct before you post it. That's basically the gist of it.... if that doesn't work try leaving the slash... but the procedure is something like that.
Nice camper!
John
Screenshot 2023-01-22 at 8.05.50 AM.png (47.54 KiB) Viewed 227 times
Capebuild
Images: 129
