Utility trailer transformation
Re: Utility trailer transformation
Postby ssrjim » Thu Mar 28, 2024 10:17 am
KCStudly wrote:
ssrjim wrote:Very little left now. I’ve been procrastinating on the rear hatch lifts. I’d like to get them right the first try...
Why not build a mockup on a flat board just to get all the geometry set. Some people have even just attached a mockup board right to their inside galley wall and used trial and error to find the best mounting locations, and then transferred to the actual wall.
I would be just as concerned with making or using adequately strong bracketry and mounting reinforcements, so as to avoid blowouts. I think people tend to underestimate the leverage multipliers involved, and some of the readily available ball stud brackets (and fastenings) just aren't up to the task. Well documented elsewhere on the forums.
Good ideas
93079
ssrjim
Postby ssrjim » Fri Apr 12, 2024 9:03 pm
Done
Time to declare this project done. Will need a mattress and a shake down run. Eventually bigger wheels and tires.Image
93079
ssrjim
Postby tony.latham » Fri Apr 12, 2024 9:30 pm
Nice job! :thumbsup:
Postby Tom&Shelly » Sat Apr 13, 2024 7:35 am
Looks great! :thumbsup:
If you are so inclined, post pictures of your first trips.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2025
Postby pchast » Sat Apr 13, 2024 7:59 pm
Beautiful! :thumbsup:
pchast
Images: 97
Postby S. Heisley » Sat Apr 13, 2024 8:32 pm
:yes:
For me, it's the cabinets and wood trim that finish it nicely. What will go in the little cubby hole on the left side of the galley counter?
Postby ssrjim » Sat Apr 13, 2024 8:53 pm
S. Heisley wrote::yes:
Not sure.
And thank you.
93079
ssrjim
