Rose Rolls - The unathorized Compass Rose autobiography
Re: Rose Rolls - The unathorized Compass Rose autobiography
Postby Sparksalot » Sun Jul 17, 2022 11:42 pm
bdosborn wrote:Water leaks?
No leaks, just needs the finish resealed.
The corner of the door I think is from water wicking up the screw holding the trim on. Not sure how extensive that one is.
Sparksalot
Images: 682
Postby Sparksalot » Sun Jul 17, 2022 11:46 pm
I might need to do some epoxy impregnating there.
As a fallback, I’ve always thought if the wood finish was ever too compromised, I’d look at an OD army tear look.
Sparksalot
Images: 682
Postby Sparksalot » Sat Jul 30, 2022 1:36 pm
Rose has had an issue for a while with sneak circuits discharging her battery. I’m guessing the added USB outlets and digital voltmeter, etc.
During the year of unpleasantness, the drain was so deep, it destroyed the battery. I had planned to add a master disconnect for a while, so with a new battery in place now is the time.
169932
The dangly down cable is much more taut. The others are power feed from the TV, and feed from the battery to the controller.
169933
Sparksalot
Images: 682
Postby Sparksalot » Tue Oct 11, 2022 5:51 pm
Recent outing with the crime scene awnings for Rose and thecopcar deployed.
170544
Sparksalot
Images: 682
Postby Sparksalot » Sun Apr 09, 2023 7:39 pm
Since Rose is now 15, I figured it was a good time for the 4th spar varnish refresher.
I also realized the finish below the fenders had never been refreshed. Note the darker, original, color.
171649
171650
Sparksalot
Images: 682
Postby Sparksalot » Wed May 10, 2023 9:40 pm
A couple of fresh coats on, then start the other side.
171882
171883
Sparksalot
Images: 682
Postby Sparksalot » Wed May 10, 2023 9:41 pm
With flash, it’s snowing!
171884
Sparksalot
Images: 682
Postby Sparksalot » Wed May 17, 2023 7:02 pm
Would you believe…
The sides I soaked in CPES during construction are still rock hard.
https://www.rotdoctor.com/products/cpes.html
Sparksalot
Images: 682
Postby bdosborn » Thu May 18, 2023 8:34 am
I remember there was an EPA mandate and they had to change their formulation. I wonder if the new recipe is as good as what you used? I used it for the wheel wells on the trailer after I saw your tests.
Images: 777
Postby Sparksalot » Thu May 18, 2023 11:33 am
I thought I had heard about it being pulled from the market. Sounds like it was a reformulation then. It’s too bad I have none of the original stuff to test against the new on the same piece of wood.
Sparksalot
Images: 682
Postby Sparksalot » Thu May 18, 2023 1:07 pm
Ugh. They were in wretched shape.
171898
Sparksalot
Images: 682
Postby Sparksalot » Sun May 21, 2023 1:06 pm
Time to wrap it up, there’s a trip soon.
171912
The 3500# axle she got 2 years ago.
171913
With a fender and Hobbit menu
171914
Curb side is shiny too.
171917
171918
171919
She even has hubcaps now.
171920
Sparksalot
Images: 682
Postby Sparksalot » Sun May 21, 2023 1:09 pm
Being a teenager, of course she has zits.
171915
171916
Really, each zit represents a spot on that side which needed extra attention.
Sparksalot
Images: 682
Postby Sparksalot » Mon May 29, 2023 10:03 pm
Next up, work on the doors. The lower trim on the street side door has been a headache since I built her.
171975
WTH, I just refinished this side. After 3 nights of torrential rains. No issues on the curb side.
171976
Sparksalot
Images: 682
Postby Sparksalot » Sat Jun 10, 2023 2:40 pm
I recently pulled the crime scene awning off of thecopcar, so Rose has double the shade installed now.
170544
172040
Sparksalot
Images: 682
