Can you believe its been 7 years all ready? I know all of you have been waiting with bated breath to find out what happened to this little trailer. I only used it once more after the trip it was built for, then I lent it to a friend who used it a few times then died (not related... I think). I had assumed it disappeared as part of his estate, and given what I had invested in it wasn't too worried about it. This changed when I ran into his widow at a vintage racing event last week-end and she asked if I wanted "that little white trailer".
So naturally I said yes and arranged to look at it... and really considering the haste with which it was built it has held up decently. Apparently it was used a few times as a trailer, then as a storage shed for a while,broken into at some point in time but overall still looks like a trailer.
A quick assessment showed the bald tires held air, and one of the tail lights still worked and the cabin was firmly affixed to the bed so I towed it home.
It looks like the shortstrand and bondo I slathered on the front curved section cracked and broke out at some point, the door strike plates were broken off, and the rear hatch was forcibly pried off. A bit of water came in the damage on the leading edge but it looks like the roof vent stayed dry and they put a drywall screw in each side to hold the doors shut so the interior is really quite good. I pulled out the mattress took the cover off and the foam looks really good with the exception of a couple divots where heavy stuff was stored on it so I'll wash the cover and roll with it. The floor is solid with only a bit of corrosion on the bolt heads that hold it to the trailer frame.
So where do I go from here? I'm thinking hit it with a belt sander, fiberglass the curve on the leading edge to seal it,fix the dangling wires, new hatch,tires and paint on it and go camping again!
Thoughts & Comments welcome!
