My build of Benroy Style Trailer
Re: My build of Benroy Style Trailer
Postby Junkboy999 » Fri Mar 08, 2013 4:48 pm
Humm
There always has to be the first to try it before the rest know if it will work or not. I would be curious to
see how much it expands in heat. Example. If you took a 3 foot section and attached it around a radius
only at both ends. Check the gap in the middle with a feeler gauge. Test it again at noon or one pm. I
used something like that on my garage where the wood rotted because it was against the concrete driveway.
Not sure about its UV rating unpainted.
Definitely let us know what you think.
Junkboy999
Images: 52
Postby AlgoDan » Fri Mar 08, 2013 5:06 pm
That's what I want to do is test it out...as for UV rating its used on home windows. And for expansion I will likely screw every 5 inches. I will let you know as time goes on...Cheers
Junkboy999 wrote:Humm
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby AlgoDan » Sat Mar 09, 2013 8:07 am
Some pics of the moulding, Its called dripcap mldg.
Trim on 3/4 ply.
103089
Trim on Radius
103090
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Sun Mar 10, 2013 6:01 am
Ok added some more moulding pics. I have profile shots of the store bought moulding and of the modified one to what I need. The one profile being square and the other having a radius...The screw caps will go into a counterbored hole. I will put a dab of sealer/caulking in each hole, then tap the cap on....
103108
103107
103104
103106
103105
Build Journal
AlgoDan
Images: 238
Postby fartblossom » Sun Mar 10, 2013 4:19 pm
Very interested in your trim. Sounds like a great economical alternative. I had been thinking of frp corner trim, but this sounds better. Will be watching for your results. Please keep posting pics. :thumbsup:
My build thread
viewtopic.php?t=55238
fartblossom
Postby AlgoDan » Sun Mar 10, 2013 4:25 pm
Thanks! fartblossom .Have been wanting to try something different and see how it goes....I have gotten so much from this site, that I could at least share an idea or two back...will keep pics coming as progress comes along.
Cheers :beer:
fartblossom wrote:Very interested in your trim. Sounds like a great economical alternative. I had been thinking of frp corner trim, but this sounds better. Will be watching for your results. Please keep posting pics. :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Mon Mar 11, 2013 6:28 am
Ok a couple of pics of the Galley hatch...Today was to fit piano hinge on Hatch to the frame for locating depth of and alignment...
103153
103152
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Mar 13, 2013 7:59 pm
Last couple of days been slow, got my Polyurethane sealant for the roof/doors and windows. Just need to glue and tack my 1/8 luan on the roof. Then finish off the Hatch with luan, and glue up both sides. Also CPESed the Hatch panels and all edges of roof panels, prior to skinning with aluminum. :beer:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Mar 15, 2013 5:35 am
Not a big job but did get the roof vent cut woohoo.....finishing up on the Galley hatch slowly.
103248
103249
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Fri Mar 15, 2013 11:20 pm
Progress is progress. :thumbsup:
Nice clean work. :thumbsup:
Postby AlgoDan » Sat Mar 16, 2013 4:55 am
Thanks KC, Just pluggin away...its getting there.. :beer:
KCStudly wrote:Progress is progress. :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Sat Mar 16, 2013 6:21 pm
Ok today did some Hatch hinge locating work again. Need to get everything lined up and sealed up. I knew this Hatch work takes TIME because so many things have to come together, for a nice fit....
Struts screwed into 1inch. Cherry for strength....
103293
103294
103296
103298
Latches Located
103299
Drip Rail
103297
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Sat Mar 16, 2013 9:35 pm
Looking good; she's really coming together now. :thumbsup:
Postby AlgoDan » Sat Mar 16, 2013 9:38 pm
Ya Thanks KC...Well you know how it goes, work work work lol.... :beer:
KCStudly wrote:Looking good; she's really coming together now. :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby Kharn » Mon Mar 18, 2013 2:18 pm
How high are you anticipating the open hatch being above the ground, vs how tall are you? :thinking:
Kharn
