Things have been going seemingly slow lately, but in fact we are very close to making sawdust... hopefully by the weekend.
The build is going to take place in my parents garage. I would like to do it our house, but his garage is much bigger and we will have a much bigger working area. The downside is that we had to put forth a MAJOR cleanout to get things where they needed to be organizational wise... needless to say that was a job in itself. However, we do have it to a workable space at this point, and now is the time to finalize all of the important stuff, and get the ball rolling.
As far as we can tell, this below is the final profile (very simple, but I had to take out all of the extras) I couldn't see the forest for the trees. I do have most of that worked out though, at least in sketchup. (door location(s), axle (44" from rear), fenders (will fit), fan/moon roof, etc)
Basically it is a 30" deep bunk area in the front, with a 24" radius off of the front. i would have liked it a little more rounded in the front, but I do like the little bit of extra space with the tighter radius in the front corners.
Total cab length is 10 - 6, and we are going to add a box on the front, build in to be accessible from the inside, much like the camp-inn, and another build that I saw here recently (
http://tnttt.com/viewtopic.php?f=50&t=59086). Haven't worked it out completely, but probably 12-18 inches on the front, curved to fit with the radius.
We are going to cut out a template from the drawings here. I already used sketcup to do an x/y, and took measurements from a reference point.
Once we have the template, we are going to mock up (with tape) the bulkhead locations, interior cabinets, bunk heights, and door location.
Trailer is in limbo right now. We have a friend who is going to move the axle (more on that in a minute), and cut back off, weld a couple new crossmembers in. Not a lot, but not my specialty... welding is not a hobby that I have jumped on (at least yet).
The axle-- while looking at the axle the other night, i noticed that it had a *very* little bit of lateral play in it. i.e. if I yank on the tire, it (the hub) would move from side to side.. maybe 1/16 to 1/8 of an inch.. not much, but noticeable. Not sure here what the deal is, or if this is normal, but as far as I know if shouldn't have any play in it... suggestions?? Other thoughts are that they axle is heavy (3500), so we are probably (most definitly) going to have to remove the smallest leaf spring, or it will be rough. Sooooo.. after reading another thread and noticing that a torflex is only about $250, we can pick it up at the dealer, we are leaning toward replacing the axle completely.
In the mean time, we are going to work on the final locations of bulkhead etc, mentioned above, and start the floor... gotta make some progress, and I figure maybe we will have an ah ha! moment about the axle and decide what to do with it.
