Started Today
Re: Started Today
Postby mrwall1 » Sun Mar 08, 2015 6:09 pm
I have been doing a few changes on the Hitch and Haul Trailer... I built a bigger shelf for the front and installed a tongue Box for my electrical... I will probably put a Propane Ring on one side and a Gas can holder on the other side.. not sure yet...
I drilled a hole in the side of the Tongue Box for the Shore Power Plug
then ran the wire to an Outlet box... and plugged a GFI plug into it..
Then I bought a 4 way plug box with a 15amp breaker in it..
I need a new Battery so for now I am just using my Jump box so I have 12 volt for the Fantastic fan
Then I mounted a 750 watt inverter (going to replace to a better model later) so when I get my new battery I can run some 110V items
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sun Mar 08, 2015 6:16 pm
I also did some work in the Galley!
I Built some Rear doors to cover the Lower shelf where the Ice Box and Oven are
The Doors each have a fold Up Shelf... One side to put the Stove on and the Other side can be used to put a make shift sink
I also added another Outlet and a vintage Weather Board...
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sun Mar 08, 2015 10:00 pm
Added a few additions to the inside of the Hitch and Haul....
First I added an overhead shelf above our heads... to put misc items...
Then I Put cable on the inside and a plug on the outside... which I can also hook up a digital antenna when no cable available...
We bought a 24 inch TV with a DVD player built in...
Also bought a couple of Bottle holders...
Mike
mrwall1
Re: Started Today
Postby 39Ratrod » Mon Mar 09, 2015 8:16 am
Your build looks great! Love all the stained wood.
It's looking at builds like yours that keep me motivated to work on mine. Thanks for the inspiration.
The biggest difference between a dreamer and a doer is the follow through.
39Ratrod
Images: 71
Re: Started Today
Postby Gold5one » Mon Mar 16, 2015 8:37 am
I like what you've done!
Mark
viewtopic.php?f=50&t=74522
Weekender-XL build journal
sold-2018
Gold5one
Images: 157
