davidAndshannon wrote:Did you use PMF or Poor man's Fiberglass on your roof? If so, do you have any photos of implementing the process?
No I didn’t use any fiberglass
I ran it for 10 hours with the lid open and it performed well but I do intend to add a vent.lincolnlerner wrote:Lots of great work here. Need to add comment on AC needing lots of space for exhaust and intake. (both for the outside of the unit) Air is pulled in from the sides, and out the back. This is the air used to cool the unit. Not the air being recirculated inside the teardrop. (Unless you open the vent then some will mix) The unit will overheat quickly otherwise. So look into a simple design to allow air flow. Thanks. Love the design
clamlamp wrote:Great job!
Just curious. Did you test the tongue box on your vehicle and do a full radius turn to see if it hits? I have a short tongue as well.
Sent from my ONEPLUS A3000 using Tapatalk
