Turned a few pages the last couple of days. We started out with getting the headboard buttoned up. Since we polyurethaned all four sides of the rails and the headboard cross members, I decided to try Titebond's polyurethane glue to attach the rails. It provided a strong bond, but made for a very messy glue up. I ended up attaching the top rail with screws instead of glue in order to avoid making a mess of the lower rail.
After the rails, we got the sliding doors for the headboard cut and dry fitted. These will get polyurethaned and installed once I have another batch of components ready for finish. The headboard shelf will be kept off until these are installed since I will have to swing the doors in place from behind the headboards.
Next, we got the vertical countertop supports installed. They were glued and screwed along the bottom, back, and top. We were pretty happy with how the jatoba edge banding turned out.
Last, we got the headliner finished and installed. My wife helped us out big time by sanding and getting the second coat of polyurethane applied while I was at work, so we were able to get it done sooner. The headliner was probably the most challenging part of the build so far for us, mainly due to some frantic trimming that had to be done with an orbiting multitool at the end because it was too long and slightly too wide. For most of the install, it felt like the headliner was more in control of the situation than we were.
Leading up to the install, I'd planned to complete it with glue and screws, however, dry fitting made me rethink how necessary a crown stapler really was for this task. I broke down and bought one and I'm glad I did. The ability to sink a large quantity of fasteners in a hurry was a big help.
The only collateral damage that occurred during this task was that we were using fairly long staples and I accidentally shot two in at a bit too much of an angle. They managed to poke through the fiberglass. Oh well. I'll sand them down with a dremel and use thickened epoxy as a patch during the fairing process.
Next up will be roof spars. These were a lot more expensive than I anticipated. $200 for five 1"x8"x10' poplar boards.
