Made some trim for the hatch and hatch access panel yesterday. Oak wouldn't have bent around the curve, so I used scraps of 1/8 inch Baltic birch, with the grain running cross-wise to accommodate the bend
I thought maybe painting them black to match the gussets, but Shelly thinks varnishing them to match the rest of the hatch interior is the thing, so I'm doing that now. When that's done, I'll glue them to the hatch and access panel.
The screws allow reasonably convenient access. They are about the only exposed screws on the teardrop (outside of the doors), and I think brass will be appropriate. Unfortunately, Amazon seems to have lost our order of brass screws, so stainless steel are substituting temporarily.
Working with thin strips of 1/8 inch plywood turned out to be a challenge. I discovered (the hard way) there is a gap at the bottom of the fence on our table saw that the wood can get wedged in, so that tool was out. I could rout a straight edge on material as thin as one inch wide, but at 3/4 inch it would bend enough to make that truly difficult.
So the first few pieces I ripped by eye with a bandsaw, sanding to bring it straight. Then I remembered Shelly has a few tools for making doll house parts: a mini-table saw, and a mini-chop saw
The table saw worked for several strips, but then began binding. At that point I had enough material that I didn't investigate further. I'm not crazy about the chop saw, only because you can't see what you're doing with that fat top blocking the view. Interesting tools though. If I ever get a project requiring enough small parts, I'll explore them further.
