The lower galley shelves are done and ready for finishing
Particularly with the pots and pans drawer and the water, I'm afraid to pull them all out at once: the tear might tip back!
Those are 150 lb rails, so I think we are okay with the weight. The left two shelves sit on the battery compartment cover. To get to the battery, all we have to do is remove the items from the drawers, remove the drawers, remove the screws holding the cover down and lift using the convenient early American style folding lift handles
Of course, by the time we need to do that, there will be a frame around the drawers to negotiate as well. Best idea I could come up with
The battery cover is 1/2 inch AC plywood laminated to some 3/16 inch non-waterproof floor material that I'd used for router templates. Before laminating, I cut out the 3/16 inch sheet around the battery case, as it is slightly proud of the floor. I plan to coat at least the underside with epoxy, and then will seal around the battery case with the same foam seal I used on the hatch. The 3/16 inch sheet should allow it to compress just right. (I'll show more pictures later.)
The boxes are all made from quarter inch AC and Baltic birch plywood, held together with strips of poplar and Titebond III
I plan to epoxy the insides for waterproofing, and then will varnish the entire thing. The lids are made out of 1/4 inch Baltic birch, glassed and epoxied on one side. Some were left over from the door cut outs from the sides of the teardrop. Some came from a mis-guided attempt to make a side panel before gluing it to the skeleton. I still have enough of that material for the silverware drawer bottom and cubby floor for the stove. I cut out the cut-outs in the lids using Forstner bits and my trusty scroll saw
My favorite part of this was the pots & pans drawer, which was so clever (if I may say so myself), I decided it could have been invented by German engineers, so I call it
das klanken gestopper.
Somewhat surprisingly, Google translate gives a correct translation of that phrase from German to English. (It's surprising because I learned all the German I know by watching Hogan's Heroes reruns.) It also does okay translating the phrase from Dutch or Afrikaners, though without the finer nuances. But I digress...
That aluminum pot contains about all of the other utensils we need
though I noticed we have no bowls. Shelly reminded me we used the aluminum bowls from our Boy Scout style mess kits for that, so we'll have to find room for them.
We bought a brand new Lodge 8 inch frying pan for the kit, since our 10 inch pan wouldn't fit. Shelly likes the fact the lid to the larger Camp Chef Dutch oven fits on the pan, but I'm not sure what will happen when we add that heavy cold piece of metal to a simmering breakfast.
The base is another piece of glassed Baltic birch over 3/4 inch AC plywood, backed by a scrap of 1/8 inch Baltic birch
I was going to use 1/4 inch BB, but realized it wouldn't quite clear the lift handle for the battery lid. Oh! almost forgot to mention: in order to keep the aluminum nested-pot-set low enough so we can store the stove above it, I had to go below the 1.5 inch tall floor mounted sliders on this drawer. I traded width for height.
I could've figured out a jig to route out the circles, but instead decided to wing it out the scroll saw. Came out okay if your don't look too closely!
Next steps are to finish these, build the frame and then the silverware drawer. Once the frame is in, I plan to build some face fronts for these.
Our plan for the counter right now is tentatively to use 1/2 inch AC (which I may make by laminating two 1/4 AC sheets--since I have an overabundance of that and no 1/2 inch on hand), and then buy some laminate to cover it. Could change our minds and go a different direction, however.
(Wow! That's a long post! Tell you what, just read the parts you are interested in!)
