HI,
I'm getting 'broken link' instead of electrical images....
Thanks,
Pete
pchast wrote:I'm getting 'broken link' instead of electrical images....
MadMango wrote:Well I didn't get the trailer wiring started, but did get more interior and exterior stuff done.
I managed to mount and power both porch lights. They still have the incandescent light bulbs, but I'll replace with LEDs after these burn out. I'll find out how much light they actually give off once it gets darker tonight. If they don't give off enough light, I might replace with LEDs sooner.
I also managed to get my LED tail lights mounted, along with my license plate holder. This is actually for the front of a truck/Jeep to mount off road lights, but I think it works well as a handle for raising the hatch and as a step to reach the top should that need arise. I still need to add a license plate light and make a harness that follows the hatch back and down through the floor to the trailer frame.
Here I finally got around to installing my 3/16" ABS fenders. I heat formed these with a heat gun and pieces of wood, held in place with clamps. As another hobby I make custom Kydex holsters, and the same techniques worked here. It just took a lot more heat and time due to the thickness and these being too large to fit in my oven.
I also added a little bling, aluminum diamond 1"x4" trim, to the lower edge of the camper. I need to order more material and lay a bead of caulk around the fenders and edges of the trim to prevent water wicking.
Users browsing this forum: MosKrat and 19 guests
