Smiles to go! Updated 8-2 new pics! First trip!
Re: Smiles to go! Updated 8-2 new pics! First trip!
Postby booyah » Wed Aug 12, 2015 1:55 pm
Post of things I DIDNT like as much
Spa sensations 4" memory foam mattress.
http://www.walmart.com/ip/Spa-Sensation ... es/4569413
Wish I'd gone with the 6". Depending on how I lay on it, I can feel the floor underneath me. I think the 6" would have been more comfortable.
Tongue jack
http://www.northerntool.com/shop/tools/ ... _200631762
Dont like how this mounts. I wish I could have found a better option. I may have one welded onto the tongue later.
"Stainless" steel pull down latches
http://www.amazon.com/gp/product/B00JR3PBTQ
Yeah stainless is in quotes there for a reason. This will be replaced sooner than later once I find something else that will hopefully use the same holes.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby KCStudly » Wed Aug 12, 2015 2:38 pm
You may be able to save those SS latches if they got a little rusty. (Remember it is "stain-less" not rust free; some grades of SS just don't do well when exposed to the weather, especially salt.)
Scrub them up with a greenie pad to remove the rust; wash and rinse well to remove any oil from fingers, etc.; cook them for 1/2 hour at 150 deg F in a 10/ct citric acid solution; rinse well but don't touch (no oil from hands) and allow them to sit dry in open air for 3 days. They are now passivated and will be less reactive to exposure. Citric powder is usually available in the canning section of the grocery or hardware store.
Postby S. Heisley » Wed Aug 12, 2015 7:27 pm
That's a great post of likes and dislikes, Booyah. :thumbsup:
Postby booyah » Thu Aug 13, 2015 9:04 am
KCStudly wrote:You may be able to save those SS latches if they got a little rusty. (Remember it is "stain-less" not rust free; some grades of SS just don't do well when exposed to the weather, especially salt.)
I'll give that a shot. In this case it seems the pin in them is actually whats rusting, and I suspect parts of them may be stainless, and parts may not.
No particular salt was applied in this case, outside whatever is on my skin due to perspiration, but I'm pretty certain I didnt get any of that on the hing pin :-)
booyah
Postby booyah » Thu Aug 13, 2015 9:06 am
S. Heisley wrote:That's a great post of likes and dislikes, Booyah. :thumbsup:
I'm debating on doing an actual full write up on my 12v power. When I was doing my research I had a ton of open questions that I couldnt seem to solve until I had my hands on the actual components, and I bet it would make some people feel better to have a good solid write up/step by step to see.
I really like how my electrical worked out, its all nice, clean, and very effective
booyah
Postby KCStudly » Thu Aug 13, 2015 10:03 am
Even if the pin isn't plain steel, it may likely be 17-4PH SS, which will rust. It is often used for that type of thing because it is harder and stronger than the alloys that have more nickel.
Postby booyah » Mon Sep 14, 2015 9:22 am
Last post on this thread for a while (I suspect) but I just got a weight on the finished trailer yesterday
With a half full cooler (coming home) but otherwise loaded for war, smiles to go weighs in at 860lbs
Had her out on a brisk overnight (overnight low was 41F) but we're now right about 1000 miles on her since the "Good enough" point.
Near future upgrades
1. Better mattress for kid bunk
2. Bed railing for kid bunk
3. 110 power for the cabin (to allow us to install a small electric space heater)
booyah
Postby Tommy2tone_1999 » Sun Feb 14, 2016 5:25 pm
Great Job!!! Nice to see you enjoying it!
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby dirtsailor2003 » Fri May 20, 2016 2:23 pm
Great Build. Thanks for including your likes list with links!
dirtsailor2003
Postby booyah » Fri May 20, 2016 2:36 pm
Thanks, getting her dusted off for another year right now.
Will probably make some updates to this post with the stuff we're doing once I have a decent number of items to add
booyah
Postby PKCSPT » Sat May 21, 2016 12:14 am
Just love the name
121172 116946 159644
PKCSPT
Images: 61
