JasenC wrote:Don't think we'll see that tank bouncing down the highway.
smeerkees wrote:Hello Marco,
I didn't realize it at first but You tig welded the frame for the water tank.(beeing aluminium) Did you also tig weld the welding work on the beginning of your teardrop build? (beeing steel).
Greetz, SmeerKees.
Marcogs wrote:...If you TIG weld your chassis, then you compromise to mutch on structural integrity.
KCStudly wrote:Understood. We (experienced welders) have a saying, "If I can walk across it, I can weld it." Which is not to say that wide root openings will result in the best welds, but it can be done with most any process.
I agree with you on many of your points. Also, TIG welding is generally a slower process than MIG. However, one of the reasons that TIG is considered a superior process, especially when compared to MIG performed by a novice (or even long time welder with mediocre skills), is because the heat at the root is much easier to see and control with TIG. Piling a bunch of filler on top of a cold root is a common problem for MIG beginners, and does not result in strong welds. (Not saying you have this problem, just trying to clarify why TIG is superior... why I used that process for my chassis build.)
You are doing fine work!
The carpet also isulates.JasenC wrote:I like it, I'm planning on doing padded fabric, or maybe now carpet, for the walls.
Thanks, it’s indeed cool to see the various ideas of al the builders.noseoil wrote:The carpet looks very nice and should add a bit of sound-deadening as well as insulation. Good to see how many different types of interior finish are being used on these home-builds. There is no limit to how creative people are when working on a build.
I like the look of the cloth instead of plain wood. We did wood walls with a very light maple stain, but the head liner was done with raw canvas. Since the interior space is so limited by the size, a light color helps keep it feeling less like a cave & more like a small room. We needed to be careful not to get finger marks when handling the headliner & setting it in place, but it's a nice finish when it's installed. No swatting mosquitos or flies on the ceiling, because the canvas is untreated & has no finish to prevent stains, but so far it still looks good & the off-white color is nice to live with, it's bright & reflects light well for reading.
