the jelly belly build
Postby Mary K » Sun Sep 21, 2008 12:28 am
Cool, :thumbsup:
Maybe you could order the cheaper foam stuff on line. Have ya thought about that? So it wont be so expensive?
:thinking: I know down here you they have a insulation for houses that can be sprayed behind the sheet rock to fill up between the studs. Try calling a local insulator business and see if they can do that for you and save you some time.
Just some thoughts....
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby del » Mon Sep 22, 2008 12:12 am
Mary K wrote:Cool, :thumbsup:
Mk
I will check with a insulation company next week, good idea Mary K.
del
del
5000 Club
5000 Club
Images: 410
Postby Mary K » Mon Sep 22, 2008 12:15 am
Every now and then I am useful.....but not often. :lol: ;)
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby del » Mon Sep 22, 2008 1:24 am
Well winter is fast approaching, so I need to get cracking on things that will make my southern migration easier (if I get to go). Insulating is the name of the game. I went to install another can of expanding foam, but nothing came out :x . So I started to work on the bulkhead. I need to add bracing for the hatch props and create me a 3/4 gap for the insulation. Here is one brace installed.
More bracing to follow. Yes it will make my galley about an inch shallower, but thats ok.
del
del
5000 Club
5000 Club
Images: 410
Postby zelix » Mon Sep 22, 2008 10:35 am
wow... I just viewed this entire thread. Man, that's a cool TD you are building there. :thumbsup:
zelix
Postby del » Mon Sep 22, 2008 3:27 pm
zelix wrote:wow... I just viewed this entire thread. Man, that's a cool TD you are building there. :thumbsup:
Thank you, del.
del
5000 Club
5000 Club
Images: 410
Postby del » Wed Sep 24, 2008 12:02 am
Inching forward, installed a whole two pieces tonight,and cut out a third.
For the pattern, of the two side pieces, I still have an extra rib from when I made the walls (I know it is cheating, but hey it has come in handy several times.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Wed Sep 24, 2008 12:30 am
A question just to the right of the two center brackets are several nuts holding in the fuse box and circuit box. When I insulate and put the other half of the sandwich in there will be no access to these. Should I put wood there with wood screws, instead of the bolt and nut? I can think of no reason to ever remove these items, but if I did.
del
del
5000 Club
5000 Club
Images: 410
Postby Juneaudave » Wed Sep 24, 2008 12:48 am
Ya know...if it's just the backside of a fuse and circuit box...even if you had to remove the boxes...you could do a fix easy enough!!! My vote is to insulate and not worry!!!
:thumbsup: :thinking:
Juneaudave
Images: 380
Postby del » Thu Sep 25, 2008 2:08 pm
Woops the corner of my insulation broke, will have to fill it with something.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Thu Sep 25, 2008 7:09 pm
Moving on on this insulation process, I need to install the clearance lights before I insulate. Now a question of style, do I install the lights pointing up or out?
Either way they are visible from the side, and I am small enough that I do not need them so, what do you think?
del
del
5000 Club
5000 Club
Images: 410
Postby Nitetimes » Thu Sep 25, 2008 8:17 pm
del wrote:.... and I am small enough that I do not need them so, what do you think?
del
Leave them in the package maybe??? :thinking: ;) ;)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby del » Thu Sep 25, 2008 11:55 pm
One of the things I need to do is adjust the door, so I can find out how much spring back the door has. To do this I had to remove the door and hog out the bolt holes so I could push in th door.
After a lot of swearing get door back bolted on, and discovered the door only moved in about half as much as it should have. :x :x
Tomorrow is another day right?
del
del
5000 Club
5000 Club
Images: 410
Postby dandan » Sat Sep 27, 2008 4:54 pm
:thumbsup: :thumbsup: :thumbsup:
hi, im a bit new to this game.
will be attempting to build a roswell out of ali next year.
i would just like to thank you for shareing your build experiences with everyone.
have just spent the last 2 hours trawling through the 57 pages & enjoyed every bit.
well done.
kind rgds dan. uk.
Nostalgia's not what it used to be !!!
dandan
Roswell Club
Images: 214
Postby del » Sat Sep 27, 2008 5:00 pm
dandan wrote::thumbsup: :thumbsup: :thumbsup:
well done.
kind rgds dan. uk.
Dan first of all welcome to the forum. I really want someone to build another one of these, so I can look at the pics of coarse and see where I went wrong. :lol:
del
del
5000 Club
5000 Club
Images: 410
Users browsing this forum: smeerkees and 14 guests
