Got some more work done on the trailer this weekend. Its finally getting to the point where I need to start spending some money on the big items like getting the trailer finished, getting door hardware and materials, and deciding on/purchasing the outer skin material. But for now I got all the outlets, lights, switch, and wire in from Amazon.
Got the dome light mounted...
Heres the rest of the stuff (less the storage outlet)...
And here is one side of how the wiring for the porch lights is gonna be. I plan on using a wire mold to cover up the wiring on the inside. It should only be about 4" long. If your wondering what that piece of cardboard is for, well, I slipped with the drill and punched an extra hole in the ceiling!
That cardboard is glued on as a backer so I can patch the hole and repaint it...
And here is from the inside. You can see the patched spot just above the hole in the ceiling...
I also got the trailer frame welded up this weekend! My buddy welded it for me in his shop. Now I just need to pick up the axle (Tuesday or Wednesday) and the material for the tongue and then finish welding her up and I can move the trailer cab onto the frame and get her rolling!
Here is a sweet little gem I found in a pile of junk in the corner of my garage. Its an aluminum rack of some sort I got a long time ago from the trash somewhere and it just so happens to hold 4 propane cans perfectly! I just need to make a strap to hold them in place. I'm way excited on this find! I guess trash comes in handy sometimes after all!
In the above pic you can see I added some material to the opening edge of the storage area so the corner trim and storage opening trim have room to mount in that spot. I just need to cut-out the tailgate and install the stops and then it will be able to go in. I've decided to coat the inside of the storage area with spray on bed liner for durability and to seal up the wood.
I'm hoping I can give some updates next weekend of the cab mounted on the trailer and rolling! Stay tuned...
Robbie
