Thank you so much Mike, the graphics are going to be the icing on the cake!!! Please let me know if I can be of any help with your build sir!
Thank you both Cliff and Sharron for your continued support of my little project too.
We didn't make it to Twain and Tears but we did work on the trailer a bit more over the weekend. The tongue box and hatch are ready for final trim and assembly.
The aluminum went on very easily then we made a ton of aluminum 'sawdust'.
While routing the passenger side, the platform slipped enough for the bit to camphor the edge a little. Thank God for molding huh?
Now on to the hinge and trim.
We finally got around to skinning the hatch with the .063 aluminum. Here it is with the vinyl contact cement in place. It takes two coats.
You can see the vinyl cement on the unfinished ply.
We worked from the bottom edge to the hinge side placing clamps and bars where needed. Here I am checking the tightness of the clamps.
I had to take one of my best pal Mark doing the same.
This is how the whole thing got clamped up.
The underside of the set up showing how we used cripples to hold up the bottom edge.
My brother's always using the table and bits of plywood for make shift clamps.
Another view.
The hatch is ready to finish.
All the best,
Dave
